Old 22-07-13, 11:23 AM   #1
MarkB852
Default LED indicators erratic flash rate.
I have a problem with my LED indicators where they will occasionally start to blink rapidly. I thought it might be a problem caused by a mis-match between the front and back indicators, I have Oxford on the front and some no-name Chinese ones on the rear, so I changed them to an all Oxford set-up... Which worked for a bit and then started doing the same old erratic blink rate.
I guess the next step is to get a replacement indicator relay and cut out all the resistors.
Any chance it's just a duff connector somewhere? I'm thinking probably not.
Thanks,
Mark
Old 22-07-13, 12:20 PM   #2
Mauler
Mauler's Avatar
Default Re: LED indicators... Oh dear.
As long as the resistors are securely connected up and doing their job it sounds like the indicator relay?
Is it all the indicators flinking fast or just one side? When they're playing up are all four working?
Mauler is offline   Reply With Quote
Old 22-07-13, 12:26 PM   #3
MarkB852
It started on the right hand side but only every now and again. Then it was always on the right hand side. I changed the rear indicators and everything was hunky-dory until I put the seat back on and then both sides started playing up. Moving stuff around whilst the indicators were going would occasionally change the blink rate but not consistently so I think it might just be the relay going weird. It's a PITA for sure.
Thanks,
Mark
Old 22-07-13, 12:51 PM   #4
bad wiring.
Old 22-07-13, 12:58 PM   #5
MarkB852
Yeah. I said something like that...
Oddest thing was turning a resistor over and watching the blink rate change. Replaced that and no difference. Taking all the resistors out would at least give me an opportunity to cut down on the amount of connectors and replace those left with my spunky new crimp tool. It does a lovely job!
Thanks,
Mark
Old 22-07-13, 01:07 PM   #6
NTECUK
NTECUK's Avatar
Removing the resivor might find the bad connection.
led compatible relays are not mega dosh .
Old 22-07-13, 01:20 PM   #7
MarkB852
True. And duly ordered from sunny Hong Kong...
Thanks,
Mark
Old 22-07-13, 01:33 PM   #8
keith_d
keith_d's Avatar
Rapid blinking is probably due to a dud resistor or cruddy connection.
The blink rate for a regular flasher relay is determined by the current drawn by the bulbs. LED indicators draw much less current than regular bulbs so we install resistors in parallel with them to increase the current drawn.
If the resistor fails or isn't connected the current decreases and the flasher relay flashes faster.
For a permanent solution you need to replace the flasher relay with one suitable for LED lights and get rid of the resistors.
If you don't want to replace your relay you should check the resistors are connected securely.
Keith
Old 22-07-13, 01:55 PM   #9
MarkB852
Just have to wait for two weeks for the LED relay to arrive. Seems like a long while but then they're half the price.
And apparently just the same...
Mark
Old 22-07-13, 04:04 PM   #10
Default LED indicators... Oh dear.
As it doesn't happen all the time I'd first look for a poor/intermittent connection. As it's the flash rate that changes, it's most likely to be a resistor that's not connected securely. When the connection is good, the system is loaded correctly, flasher unit works right. When the connection is poor/missing there's not enough load - fast flash as the unit 'sees' a dud bulb.
Bin the resistors, fit a suitable flasher unit.
Oh dear, oh dearie dear, oh dear. Lozzo Idle Banter 33 05-10-11 08:50 AM
Oh Dear Oh Dear...The problem with fitting a BMC Filter and rejetting is............. Dappa D SV Talk, Tuning & Tweaking 36 15-09-08 05:24 PM
oh dear oh dear - summertime Balky001 Bikes - Talk & Issues 53 27-06-08 01:53 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
