Old 22-07-13, 02:27 PM   #1
veenee
Default Poor brakes - pads and lines?
I had a chance to test ride some Suzukis last Saturday, and apart from realizing how much I love SV, I also noticed that my brakes are not good at all.
So brain storm began - what to do?
I don't think I will be trying to swap brake system for something from another bike (if possible at all) so I am thinking about getting braided lines and new pads (although mines are absolutely fine - plenty of 'meat' still on them). I've got some questions then:
1. Is it a good idea to change lines and pads at the same time? Does it make anything easier/harder (never done anything on brakes apart from changing fluid)?
2. Which lines should I get?
3. Which pads should I get?
4. Should I change pads at all?
5. Is there anything else I could do?
Thanks in advance!
Old 22-07-13, 02:31 PM   #2
Default Re: Brakes - pads and lines
when was the last time the callipers were serviced, e.g. stripped, cleaned and greased?
Old 22-07-13, 02:33 PM   #3
veenee
probably - never
Old 22-07-13, 02:36 PM   #4
well that's a good place to start rather than spend money on things that are going to make no difference unless the callipers are in good state to begin with.
Old 22-07-13, 02:39 PM   #5
veenee
ok - good suggestion
I guess I just have to figure out how to do it.
Lines need to be replaced anyway (according to service schedule) so I could as well get proper ones...
Old 22-07-13, 02:54 PM   #6
don't worry to much about the rubber lines but since your draining the system then i suppose now would be a good time to put some braided on.
once you learn how to service your callipers i would suggest that you do it once a year. doing this will save you money and keep your brakes in tip top condition.
the SV brakes are more than up to the job of stopping the SV if working correctly.
Old 22-07-13, 03:04 PM   #7
jambo
jambo's Avatar
As above, maintenance first, replacement parts 2nd.
I'd personally strip & rebuild the calipers, using red rubber grease on the seals, boots & sliders. I'd also clean the discs and pads up with some cloth and brake cleaner or other high flash point de-greaser. If you have any build up of dirt in the holes in the discs, take the time to clean those out before cleaning the discs. Put the pads back in the same calipers, and do not get any oil or grease on the friction surfaces.
Bleed the system through with fresh DOT 4, or 5.1 fluid (5 is different stuff entirely and not suitable for the road) depending on how flush you're feeling. I've yet to have an issue with standard DOT 4 even under track conditions so I'd say that's just fine.
At the same time, take the brake lever off, clean the pivot and the surfaces, and just put a little dab of red rubber grease / silicone grease on the surface of the master cylinder piston where the brake level nub touches it. You're rebuilding the whole lot, it'd be a shame if it felt bad because of a gummy lever
Jambo
Old 22-07-13, 04:15 PM   #8
a_monkey_hint
Default Re: poor brakes - pads and lines?
Rebuilt mine earlier this year - had 3 seized pistons! Well worth stripping the calipers and seeing whether they're working correctly.
Old 22-07-13, 04:37 PM   #9
veenee
thanks Jambo, I changed fluid about two months ago, so I don't think I have to do it again.
but will definitely do some proper cleaning.
still would like to replace the lines - any suggestions there?
Old 22-07-13, 04:41 PM   #10
cleaning callipers involves replacing brake fluid. you have to strip the callipers down to individual parts, this includes popping the pistons out and cleaning behind the seals.
Braided lines and brake pads Fallout Bikes - Talk & Issues 11 29-01-13 03:56 AM
Brake lines and pads? saintnick SV Talk, Tuning & Tweaking 2 22-10-11 06:46 PM
HEL Brakes lines, £49.45 hongman Bikes - Talk & Issues 6 19-07-11 12:28 AM
Changing Brakes and Lines. Advice please. Diveboy SV Talk, Tuning & Tweaking 11 10-04-06 02:08 PM
braided brake lines & hh pads lurcher SV Talk, Tuning & Tweaking 11 12-05-05 07:13 PM
