Old 23-07-13, 09:49 AM   #1
jon_valentine
Junior Member
Default SV650 02 switchgear connectors - where from?
Hi I am trying to extend the switchgear connectors for a handlebar lift.
Can anyone advise me what type of connectors suzuki uses to connect these to the main wiring loom. The right hand connector says y701 and had 9 pins.I would lie to buy a male and female and just insert a length rather than cut anthing. Thanks for you help
jon_valentine is offline   Reply With Quote
Old 23-07-13, 10:26 AM   #2
Default Re: SV650 02 switchgear connectors - where from?
The Japanese manufacturers use all sorts of specific and bespoke connectors, I'm not saying you'll never find them, but I wish you the best of luck.
I don't see any problem with simply extending the wires, as long as it's done right it will not be a problem. If you really must use the original style blocks, it would probably be easiest to source a used loom and switchgear set.
Old 23-07-13, 10:58 AM   #3
Geodude
Geodude's Avatar
Pm Bibio on here as iirc he used to make and sell switchgear extensions so he might be in the know?
Right hand switchgear for curvy sv650 Jammy Stuff Wanted 1 02-06-13 10:31 PM
SV: Switchgear Whyte25 Stuff Wanted 0 17-06-11 10:58 AM
R. H. Switchgear Normski Stuff Wanted 2 10-03-08 09:18 PM
RH Switchgear plowsie Stuff Wanted 7 26-04-07 05:02 PM
SV650/1000 K3 onwards GPS connectors? Brucey SV Talk, Tuning & Tweaking 1 12-12-05 12:41 PM
