Old 26-07-13, 10:52 PM   #1
rapidgaz
rapidgaz's Avatar
Default Which comfy grips?
Any 1 recommend a more comfy grip over standard. Cheers.
rapidgaz is offline   Reply With Quote
Old 27-07-13, 01:12 PM   #2
TheRuffellator
I've always found renthal grips to be pretty good.
Sent by carrier pigeon
Old 27-07-13, 01:29 PM   #3
Default Re: Which comfy grips?
Renthal ones are spot on, but standard ones are fine too. Generally if the grip is not comfy you're gripping too hard.
Old 27-07-13, 06:49 PM   #4
rapidgaz
rapidgaz's Avatar
Could just be my age. Lol
Getting a bit of pain at the bottom of my palm. Also get some pins needles in same hand. Rh.
Old 27-07-13, 07:45 PM   #5
Leaning on the bars too much and/or levers adjusted at wrong angle
Old 28-07-13, 07:43 AM   #6
TheRuffellator
+1 for that, try gripping the tank with your knees more so you're not holding yourself up with your hands. I find sitting a bit further back helps, although it does take a bit of getting used to. Hope this helps.
Old 28-07-13, 03:38 PM   #7
Whitty
Try some 'grippier' grips so you don't need to cling on so tight. Renthal soft compounds on mine are ace. They are cheap enough to replace if you wear them also. Make sure you glue them properly, especially soft compounds.
Old 28-07-13, 09:29 PM   #8
rapidgaz
rapidgaz's Avatar
Cheers guys, think I will try em.
Comfy kit littleperson Stuff Wanted 8 31-10-11 08:18 AM
Something comfy all rounder stuartyboy Bikes - Talk & Issues 26 19-08-10 11:19 AM
How Comfy is your seat? $tevo Bikes - Talk & Issues 33 13-08-07 04:58 PM
Leathers + 25+ all day = not comfy... MavUK Idle Banter 11 10-05-06 10:54 PM
comfy posterior madmal Bikes - Talk & Issues 15 10-05-06 10:33 PM
