Old 31-07-13, 07:02 AM   #1
BigV
Question Temp readings going up and down
Hi,
Was riding my SV to work this morning, 49km trip, and it was about 5 degrees. I was travelling at about 130km/h and noticed the temp reading was sitting at about 75 degrees. Then it went to 76 and I thought huh, so I kept an eye on it and sure enough in the space of about 5 seconds it hit 77 then 78. Then it went down to 77, 76, 74, 73, 72 in about 4 seconds. Then again it climbed to 78 in about 8-10 seconds and again, it went back down to 72 quicker than it went up.
I then dropped by speed to 100km/h and checked again and sure enough, the same thing happened.
I'm not sure if this is normal, or if the cold air outside was messing with the readings somehow? It's the first time I have taken the bike out in Winter at this temp...maybe she was just not happy?
Anyway....not sure if this is normal for SV650S models (K7)...if it's not, could there be a problem and what could the problem be? Bike otherwise rides 100%, no issues...
Old 31-07-13, 07:09 AM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: Temp readings going up and down
Funny, that this has just been asked (and answered) over in Bike talk about 2 days ago.
Have a look but changing about 10 to 15C is normal for an SV.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 31-07-13, 07:40 AM   #3
BigV
Thanks! Let me take a look...and here I thought I had a unique issue, guess not!
EDIT: Here is the thread for anyone else, with some replies. FYI - temp fluctuations are perfectly normal in recommended operating temperature range
http://forums.sv650.org/showthread.php?t=201990
Old 31-07-13, 11:32 AM   #4
instigator
If it fluctuates wildly, it can also be a sign of air being trapped in the cooling system - easy enough to bleed it out.
Mystery connector and URGENT advice on R/R readings needed. daveyrach SV Talk, Tuning & Tweaking 19 03-10-11 07:27 AM
Oil Temp, Engine Temp and Rad Temp Owenski Bikes - Talk & Issues 0 30-06-11 09:36 AM
M/Meter readings - charging system. RobH13 SV Talk, Tuning & Tweaking 15 18-10-09 05:56 PM
New speedo drive but giving me false readings! Protocol SV Talk, Tuning & Tweaking 4 22-09-09 10:36 PM
Valve Clearance Readings Mr_Chin SV Talk, Tuning & Tweaking 2 22-12-08 08:54 AM
