Old 08-08-13, 12:24 PM   #1
iprideaux
Default Which battery?
Hi All,
My reg/rec went bad and boiled my battery dry (3rd time, carp Suzuki electrics )
So I've got a choice:
Exide (TheBatteryShop.co.uk) 9.5Ah ???A ColdCrankingCurrent £40
Varta (watchbattery.co.uk) 11Ah 140A ColdCrankingCurrent £52
Yuasa (TheBatteryShop.co.uk) 10Ah 175A ColdCrankingCurrent £57
Will the cheap Exide be sufficient?
If not, do I want the higher capacity/lower current Varta, or the lower capacity/higher current Yuasa?
Does it really make much difference anyway?
Old 08-08-13, 12:44 PM   #2
Default Re: Which Battery
for the 12 http://www.ebay.co.uk/itm/Yuasa-YTX1...item5d36767c6f
for the 9 http://www.ebay.co.uk/itm/Yuasa-YTX9...item3a837eda7f
Old 08-08-13, 01:33 PM   #3
Try MDS batteries
Old 08-08-13, 01:41 PM   #4
reaprime123
+1 MDS - Just got a YTX12-BS Yuasa for £35 delivered
Old 08-08-13, 04:04 PM   #5
TheRuffellator
Default Which Battery
Have you had a look at the motobatt batteries? I've use them a couple of times and I can't fault them at all.
Sent by carrier pigeon
Old 08-08-13, 05:29 PM   #6
stuR
yuasa for me.
Old 08-08-13, 11:04 PM   #7
madcockney
Default Re: Which battery?
If you want to see in depth test comparisons between batteries (American site) including Motobatt have a look here.
Many on the Suzuki Owners Club site like Motobatts, but they are expensive.
I have had a Varta, which was brilliant for about 18 months or so and then appears to have lost a cell.
I will be replacing with a Yuasa, but at MDS these are not due back in stock until 19th August and I registered my interest with them to let me know when back in stock a week or so back, which others can do as well. At present they do appear to be the cheapest by far for Yuasa. Luckily I have a cheap spare as a standby.
madcockney is offline   Reply With Quote
Old 09-08-13, 06:11 AM   #8
stuR
Ive always found them to be cheapest on ebay personally
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
dead battery - possible reg/rec + battery? collis SV Talk, Tuning & Tweaking 8 20-09-10 02:47 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
