Old 08-08-13, 07:28 PM   #1
Default Leaking Scottoiler.
I stripped out my scottoiler today because it's been leaking oil all over my subframe and I'm getting sick of spinning up the rear in the rain.
Ended up having to take off all the plastics to clean everything up. Battery tray had some nice sludge in the bottom. The oil had greased up the tape on the loom too so had to remove all that, clean it up and re-tape it. There was oil in some of the connectors too and in the ECU plug.
If I ever get another scottoiler it will be mounted externally. For now I'm getting some chain lube.
One question: Can I link the two vacuum connections with a pipe or do they need to be separate?
Old 08-08-13, 07:31 PM   #2
Default Re: Scott-wiring-oiler
separate as far as i know.
why is the oiler leaking?
Old 08-08-13, 07:49 PM   #3
admin
John T
admin's Avatar
I've had three Scotties and never had a failure like that.
sent via semaphore
Old 08-08-13, 08:22 PM   #4
Default Re: Leaking Scottoiler.
Dunno what went wrong with it. Seemed to be seeping from under the adjustment wheel. The breather didn't look very clean either
Oh and in other oil leaking news, the breather hose by my starter motor had a wet tip. What does that mean?
Old 08-08-13, 08:26 PM   #5
thank you title fairy and section fairy
Old 08-08-13, 08:32 PM   #6
fizzwheel
fizzwheel's Avatar
Have you spoken to Scotoiler, If its got a fault on it, they might well ask you send it back and repair / replace it.
They've been known to do this a few times. Their after sales care is pretty good, might be worth a try ?
I've never know them leak like that. The only time I have had a problem is when I have left it set to prime or had it turned up to high.
Old 08-08-13, 08:35 PM   #7
Littlepeahead
Littlepeahead's Avatar
Mine stopped working and the oil went white. Rang Scottoiler and they asked me to send it back. Replacement arrived within a week. No quibbling and very helpful.
Old 08-08-13, 08:38 PM   #8
Hmm might go get it out the bin then. Did you need a receipt or anything?
Old 08-08-13, 08:52 PM   #9
fizzwheel
fizzwheel's Avatar
I believe they have replaced ones before that have been old and well past the point where it would be reasonable to ask for a warranty repair.
I've never sent one back so its only 2nd hand information, but if what I've read is true I think it would be worth a try.
Old 08-08-13, 09:28 PM   #10
Water contamination? Where did you have the breather pipe?
scott oiler Shaun. For Sale - Other Bikes and General biking items 1 23-07-11 10:59 PM
scott oiler cymroboi For Sale - Other Bikes and General biking items 4 07-12-09 11:17 PM
Scott Oiler Speedy Claire Bikes - Talk & Issues 20 15-07-09 02:51 PM
Scott Oiler metalmonkey Stuff Wanted 1 15-01-08 10:07 AM
Where to fit a scott oiler? LindaS Bikes - Talk & Issues 5 29-11-07 07:19 PM
