Old 14-08-13, 07:33 AM   #1
Corny Gizmo
Default Connector Needed (Solenoid 3 pin)
Morning all,
im after a connector for my 99' curvy, its for the solenoid (3 pin connector on the top) preferebly off a loom so it has some length of wire on it. Mine is damaged and only working due to a bodge job
does anyone have one spare of an old loom or know a good place to get one?
only one I found on ebay is from US, be bothered waiting
cheers
Ryan
Old 14-08-13, 01:02 PM   #2
It has standard spades on it - use some crimps and put the wires on manually.
Old 14-08-13, 01:43 PM   #3
Corny Gizmo
Default Re: Connector Needed (Solenoid 3 pin)
you mean bypass the connector and just wire straight to the solenoid?
Old 14-08-13, 04:58 PM   #4
Yes. The block is just a holder for the actual spade connections. Obviously you'll need to make sure you plug the individual wires into the right spots, but it's an easy, cheap and perfectly good way of making the connections secure and efficient.
Old 14-08-13, 05:18 PM   #5
Corny Gizmo
Sounds like a plan mister squid, thanks mate
1999 SV650 Starter solenoid connector replacement? volvoboy73 SV Talk, Tuning & Tweaking 2 10-12-13 03:46 PM
Mystery connector and URGENT advice on R/R readings needed. daveyrach SV Talk, Tuning & Tweaking 19 03-10-11 07:27 AM
Electricial problem - multi pin connector on solenoid. collis SV Talk, Tuning & Tweaking 7 05-02-11 06:02 PM
Connector Rod - Help needed! Fraser SV Talk, Tuning & Tweaking 2 14-06-08 03:01 PM
Solenoid urgent Dangerous Stuff Wanted 0 19-03-06 11:11 AM
