Old 27-08-13, 06:17 PM   #1
Nobbylad
Nobbylad's Avatar
Default OMO - welding thin metal - advice please
The Doris has broken one of her favourite lampshades in the living room. It's one of three and you can't get them, or anything like them anywhere on the planet (or so I'm reliably told ).
So I'm looking for a way of welding the arms or similar. They're very thin metal and I can't think of any way of fixing them other than welding them, but that seems a bit extreme.
Any advice/ideas gratefully received!
Old 27-08-13, 06:32 PM   #2
flymo
flymo's Avatar
Default Re: OMO - welding thin metal - advice please
piccy?
Old 27-08-13, 06:32 PM   #3
solder them?
less extreme than welding
I'd successfully soldered a broken fishing rod line guide before, I just heated the joint up by holding the soldering iron near the joint until it was hot enough to melt the solder.
Once the solder melted, I took the iron off & the solder set
The line guide was made out of thin wire
Old 27-08-13, 06:33 PM   #4
DJ123
DJ123's Avatar
Using a low power Arc welder should do the trick. Is there a local blacksmith/metal work shop that could have a look and advise as to what they recommend?
BMW F800ST
Old 27-08-13, 07:19 PM   #5
braze with silver solder.
if its really thin don't even think about welding it unless you have a very very good tig or oxy torch.
Old 27-08-13, 07:44 PM   #6
+1, a welder will blow that to pieces, unless a mig on low power and tiny blobs joined together, this takes a lot of time and skill.
Silver solder is much lower temp, or even braze with brazing rods, providing it won't ruin the finish of the item.
Old 27-08-13, 08:05 PM   #7
TicklinJock
TicklinJock's Avatar
The parts might have been "spot welded" together.
TicklinJock is offline   Reply With Quote
Old 27-08-13, 08:05 PM   #8
markc123
If you are still stuck next month, I can lay my hands on some silver solder and an iron with which to use it. Won't be back in your neck of the wood until then though.
Old 27-08-13, 08:38 PM   #9
Nobbylad
Nobbylad's Avatar
Thanks all. Off to Google silver soldering.
Old 27-08-13, 08:56 PM   #10
Silver soldering should be fine. You'll need map gas and a Rothenberger torch.
It's a very fine and strong weld, which is used on air conditioning piping. When I say strong, the systems are strength tested at 32 bar and vac tested to less than 1 Tor
sent from the shredded wheat factory
metal mastery advice needed GSXR. SVMAT Bikes - Talk & Issues 9 26-11-10 02:41 PM
Danger! Thin ice... maff Photos 0 10-01-10 11:39 AM
Aluminum Welding Advice/Help Sideshow#36 SV Talk, Tuning & Tweaking 10 13-06-08 07:40 PM
Plastic welding advice philbut Bikes - Talk & Issues 14 17-08-07 03:03 PM
metal tank?(map holder advice sort) Massive Action SV Talk, Tuning & Tweaking 10 13-03-07 01:01 PM
