Old 28-08-13, 04:50 PM   #1
screamingnoob
Default R6 throttle tube fitting problem - Pointy.
ive just bought a yamaha r6 throttle tube for my 2010 sv650s pointy it fits in the housing fine but there is loads off play i adjusted the cables as much as they would go but it was no different is there a certain year of throttle tube to fit a certain year of bike has anyone else had this problem????
Old 28-08-13, 05:21 PM   #2
screamingnoob
Default R6 throttle tube problem
Old 28-08-13, 05:31 PM   #3
Nutsinatin
Nutsinatin's Avatar
Default Re: r6 throttle tube problems
2004 R6 tube fits curvey, but needs modification for a pointy.
http://canyonchasers.net/shop/bike/r6-throttle.php
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 28-08-13, 06:40 PM   #4
Lozzo
Default Re: R6 throttle tube problem
2004 model is the one I used
Old 28-08-13, 08:45 PM   #5
NTECUK
NTECUK's Avatar
do you still need to cut this bit
Old 29-08-13, 11:08 AM   #6
nikon70
Default Re: R6 throttle tube fitting problem - Pointy.
yes -
"On the Gen-II’s a little bit of the tube needs to be cut away otherwise the throttle will not return to a fully closed position"
R6 throttle tube mod - Pointy? Fifteen15 SV Talk, Tuning & Tweaking 16 15-06-12 07:30 PM
SV K5 throttle tube - fitting heated grips. TeddyBearKing SV Talk, Tuning & Tweaking 5 07-12-09 10:23 AM
pointy throttle tube andyrs Stuff Wanted 3 20-08-09 03:17 PM
Throttle tube / cable problem? Holdup SV Talk, Tuning & Tweaking 3 26-06-09 12:56 PM
