Old 05-09-13, 09:15 AM   #1
granty92
Default Delkevic baffle fitting?
So I got my delkevic stubby, it sounds absolutely mental butttttt I feel I'm just going to be pulled loads so want to put the baffle in, I have no idea how to? Anyone got this exhaust who can shine some light?
Thought I'd upload it so you know what can I'm on about
Old 05-09-13, 09:28 AM   #2
Daniel Louis
Default Re: Delkevic stubby help
Don't worry about it and enjoy the noise!
Old 05-09-13, 11:59 AM   #3
nikon70
if it supports a baffle it will have a hole in the outlet which is where the baffle bolts to, if this hole is not there not to worry you can get one (typically off ebay or have one made from your local metal fabrication place (ensure the end that goes into the can is sealed with holes in the pipework (start with a few until you get the right noise you want) and use a nut and bolt to secure it to the outlet pipe (you will need to drill a hole in that, debur it with a file or a debur tool.
you might find a suitable bafle on ebay
Old 05-09-13, 12:18 PM   #4
granty92
ill upload a picture when im home, it came with a baffle but looks like it bolts to the end closer to the link pipe rather than the exit of the exhaust, would that be right?
Old 05-09-13, 02:42 PM   #5
nikon70
Default Re: Delkevic baffle fitting?
doubt it...
Old 05-09-13, 03:14 PM   #6
nikon70
this was the one i had and you can see there is a hole on the outlet where the baffle is meant to bolt...
Old 05-09-13, 03:45 PM   #7
granty92
the hole on mine is the other end
Old 05-09-13, 04:16 PM   #8
nikon70
Might well be if the baffle is long enough to fit down there ... Take photo of baffle too
Old 05-09-13, 04:50 PM   #9
Redmist
on mine on the CBR, it is fitted at the link pipe end yes. bit of pig to ram in but it goes eventually. ooohh errr
Old 06-09-13, 09:44 AM   #10
granty92
cheers redmist, just wanted confirmation have put it in now and all is good
Which can Delkevic or MTC? sv650ollie SV Talk, Tuning & Tweaking 14 13-02-11 05:57 AM
Will fitting a baffle affect performance? Telford_Tim Bikes - Talk & Issues 19 26-07-10 09:28 PM
Fitting a baffle: Question thor Bikes - Talk & Issues 1 06-11-09 12:10 PM
Delkevic wheels TOLAROS SV Talk, Tuning & Tweaking 1 16-02-09 08:50 AM
Fitting Blue Flame Evo Baffle JakeRS SV Talk, Tuning & Tweaking 6 23-04-05 10:20 AM
