Old 08-09-13, 10:12 PM   #1
stranger12
Default sv650 timing inspection bolt
Hello,
While I was trying to check my valve clearance, I snapped the head of the torx bolt so had to remove it using vice grips.
Now I need to buy this and can not find it on ebay, is there a website apart from stealer which has all parts and bolts in the UK ?
or is my only option stealer?
Also when checking the clearance the inlet was 0.15 and exhaust 0.20
according to UK Haynes manual, the inlet should be between 0.10 and 0.20 and exhaust between 0.20 to 0.30, is that correct ? isn't that gap to wide?
Old 08-09-13, 10:35 PM   #2
What Torx bolt, where is it? Are you referring to the 10mm hexagon recess aluminium plug in the side of the alternator case, or the 8mm hexagon steel recess plug in the top?
'Stealers' should give away parts for free - they don't deserve to get paid.
Old 08-09-13, 11:06 PM   #3
stranger12
Default Re: sv650 timing inspection bolt
I think it would be the 8mm hexagon as pictured below. it is the one on top where you can read the F and R mark
http://www.msa-direct.co.uk/ProdImag...GBR-p3-640.jpg
Old 08-09-13, 11:18 PM   #4
Suzuki dealers sell Suzuki parts.
Old 09-09-13, 09:51 AM   #5
09248-16012
part number
£4.27
On offer at moment, robinsons foundry (new price £1.57)
HTH
Old 09-09-13, 09:58 AM   #6
stranger12
thanks for this, where did you get the part number from , is there a website for it ?
Old 09-09-13, 10:12 AM   #7
see above
Shoei inspection after crash? sc00by Bikes - Talk & Issues 5 01-06-12 07:50 PM
Timing inspection plug thing - how to get new one Durbs SV Talk, Tuning & Tweaking 7 12-09-08 07:31 AM
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator ThEGr33k SV Talk, Tuning & Tweaking 0 25-11-07 12:22 AM
Cleanliness inspection from Kwak required! monkey SV Talk, Tuning & Tweaking 19 18-09-07 11:00 PM
Timing Retard eliminator for my sv650 ton up tony SV Talk, Tuning & Tweaking 4 04-02-06 08:25 PM
