Old 11-09-13, 04:52 PM   #1
craig dow
Default What RPM for gearchanges?
Hi I'm new to big bikes so forgive me if this is a stupid question what rpm do you change gear at ? I use a roads mainly at 60 mph find around 7000 rpm the bike is a lot better , should I be changing gears a lot sooner ? Or does it just depends on conditions etc ? Thanks for any input
Old 11-09-13, 04:54 PM   #2
Tomor
Tomor's Avatar
Default Re: rpm
Change at the redline For me it depends on the road condition, things around me, what i'm feeling like, if i'm trying to catch/get away from someone. I don't have a fixed RPM I change gear at.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 11-09-13, 05:00 PM   #3
Biker Biggles
Biker Biggles's Avatar
Default Re: rpm
What bike?
An SV 650 is quite happy at 3500 while an IL4 would need rather more to be smooth and would deliver loads of power right up to the red line.An SV delivers a bit more power up at the top end but 7000 is plenty in the real world for rapid riding.
Old 11-09-13, 05:11 PM   #4
Default Re: rpm
what ever the bike wants to be at.
Old 11-09-13, 05:24 PM   #5
craig dow
Default Re: rpm
OK thanks for that , didn't know if I would be thrashing the engine in that rev range in low gears or not , would ridding at high revs cause more petrol use ?
Old 11-09-13, 05:38 PM   #6
Fallout
Fallout's Avatar
Default Re: rpm
When cruising, I change up very early. 6k on the gixxer, which revs to 16k I think, and maybe 4k on the Tiger which revs to 10k. It's just easy on the engine and better for fuel economy. But never leave yourself short on power in dangerous situations. If there's lot of traffic about, multilane roads etc. you really want to be in the power band in case you need to nip out of harms way.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 11-09-13, 06:05 PM   #7
craig dow
Default Re: rpm
Makes a lot of sense , thanks, by the way I have a tt600 , 2003
Old 11-09-13, 06:18 PM   #8
ChrisCurvyS
ChrisCurvyS's Avatar
Default Re: rpm
This. You want acceleration immediately available in case you suddenly need to get away from someone swerving into you.
As regards economy, the basic rule of thumb is whichever amount of revs requires the least amount of throttle.
Red Suzuki GN 125 - sold
Black Yamaha XJR400 - sold
Current - 2000 SV650S curvy, red. 1969 VW Beetle for the snow.
ChrisCurvyS is offline   Reply With Quote
Old 11-09-13, 09:40 PM   #9
Matt-EUC
Pin the throttle, dump the clutch, make sure you keep all your weight to the front of the bike and change up when you hit the red line.
Old 11-09-13, 09:46 PM   #10
The Idle Biker
Default Re: rpm
You can't be serious
