Old 28-09-13, 07:02 PM   #1
Mikey360
Default Lost bolt on rear set? Pointy.
So on the way home tonight, just got about a mile out and when I went to change into second gear, the whole lever just swung up!
Naturally I thought the worst and thought the gear box had failed or something....
Turns out the lower bolt holding the rear set in place had disappeared?
Just wondering if this is common or if it's a tell tale sign of wear for something else.
Its a pointy that's covered just over 42000 miles and is well looked after.
Old 28-09-13, 07:17 PM   #2
Default Re: Lost bolt on rear set??
well looked after includes checking bolts for torque. or someone has tried to pinch your rearset.
Old 28-09-13, 07:19 PM   #3
Mikey360
Good point haha, and It's kept in a plant tunnel tent thing well out of the way at work, can't think that anyone would see it there or that the customers that we get in would want to steal it!
Old 30-09-13, 10:30 AM   #4
jambo
jambo's Avatar
Default Re: Lost bolt on rear set? Pointy.
I'd assume the bolt was loose and has fallen out. You'll need another one, might be worth running over the bike checking other bolts are tight.
Jambo
Lost engine bolt, replacement? jonnysv650s Bikes - Talk & Issues 2 27-04-13 10:50 AM
Rear Sprocket Bolt -where from? Scott S SV Talk, Tuning & Tweaking 11 11-07-10 08:43 PM
lost bolt skeetly SV Talk, Tuning & Tweaking 1 05-04-09 11:13 AM
Lost bolt from wing mirror krhall Bikes - Talk & Issues 2 11-02-09 02:12 PM
Rear Sprocket Nut & Bolt andyb Stuff Wanted 0 04-10-06 11:42 AM
