Old 29-09-13, 04:19 PM   #1
millemille
Default What are these brackets for? Curvy.
As per the title, what are the oval brackets welded to the inside of the frame/headstock with the two tapped holes brackets used for on a K2?
millemille is offline   Reply With Quote
Old 29-09-13, 06:15 PM   #2
Default Re: What are these brackets for?
IIRC they're off a cable guide and hold the choke, clutch and throttle cables
sent from the shredded wheat factory
Old 29-09-13, 06:22 PM   #3
millemille
Ta
Old 30-09-13, 10:40 AM   #4
m`baubz
Default Re: What are these brackets for? Curvy.
fairing brackets attach to them too
Old 30-09-13, 11:30 AM   #5
From memory, on the models fitted with passive exhaust air systems the vacuum valve gubbins mounted thereabouts.
GSX-R Caliper brackets - where from? mikerj SV Talk, Tuning & Tweaking 6 27-07-12 07:38 PM
Brackets for lowers - where from? tango SV Talk, Tuning & Tweaking 14 12-08-10 06:51 PM
fairing brackets stamasman Stuff Wanted 2 28-07-10 04:09 PM
Bellypan Brackets? Damian SV Talk, Tuning & Tweaking 1 30-11-09 12:55 PM
Brackets jon8oy Stuff Wanted 1 02-12-07 02:56 PM
