Hi hope someone can help me, i have till 25/10/2013 and then my restriction is up, 4 DAYS TO GO cant wait, My bike as washers and a throttle stop on it, do i take the whole air box off to remove the washers? and i cant see how to remove the throttle stop.
Advise please. |
you need to remove the air box for the washers mate as thats how i done mine, and if you look through the right hand side of the bike frame and pull the throttle you will see whats stopping the throttle going all the way
Which exact model of bike have you got?
K4 Naked on an 08 plate.
I thought the washers and throttle stop was only on the carb model. A K4 should be a pointy with fuel injection, so it's likely to be restricted via the ECU. K4 on an 08 plate is quite a gap, what's the story there?
These are the bits you are looking for
![]() The washers will be in the inlets between airbox and Throttle Bodies. The throttle stop will be on the left (as you sit on the bike) of the TB's and you need to unscrew it.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold 2012 Street Triple R - For Sale - Linky here |
![]() ![]() Last edited by sm650n; 22-10-13 at 07:15 PM. |
if you sit on the bike its on the left hand side on the throttle bodies.
turn throttle you should see moving parts/cables and there will be a cross head screw which holds it in place T-plate in place. I found mine very tight and almost rounded the top. You will need a long screw driver. should take 5 minutes to do. I took throttle bodies off to get easy access to the screw. |
#9 |
Thanks everyone for your input will try and remove them at weekend.
#10 |
Mate you need to be really careful when removing the throttle restriction. I did this to my bike and the washers were straight forward enough but the throttle stop was a real pain in the ****ing ass, I'd advise you to download the service manual for your bike and follow the instruction to remove the throttle body off and take the screw out which holds the plate in, as not only is it a pain in the ass to try and undo it through the frame but I found on my bike at least it's head stripped pretty easily and believe me you do not want to have to drill a screw out from a throttle body as
I had to :L I've got a set of fairly crap instructions which came with my kit, if I can find them I could email you a picture of them if you want? |
The best way to remove an old gasket ? | wattyfred89 | SV Talk, Tuning & Tweaking | 5 | 08-07-10 09:52 PM |
best way to remove carbs? | Dave20046 | SV Talk, Tuning & Tweaking | 21 | 14-09-08 12:57 PM |
How can i remove anodising? | svrash | Bikes - Talk & Issues | 3 | 18-01-07 02:09 PM |
What's it for and can I remove it? | mastiffmat | SV Talk, Tuning & Tweaking | 3 | 09-11-05 11:05 AM |
Sorry old. Please REMOVE | Richie | Bikes - Talk & Issues | 4 | 19-03-05 09:59 AM |
