Old 24-10-13, 07:55 PM   #1
byron126
Default K6 headlights not working at all?
Hi there guys I've encountered a problem with my sv where my headlights simply don't work at all. The bike wont even register as if the headlight even exists :L the main beam indicator light doesn't come on the dash when you flick the switch, again it doesn't come one when the pass light is pressed I'm reasonably certain its not the bulbs as it seems a little unlikely for both bulbs to go at the same time and if they did surely it would register on the dash when you switched to main beam. On a "side" note the sidelights are on all the time even when the bike is running and driving, whereas the headlights aren't. I have read of a couple of people having the same problem as me in the past where the contacts in the starter switch deteriorate over time. Any help would be really appreciated as "Winter is coming" and I don't like the idea of it being dark and having no headlights
Regards
Byron
Old 24-10-13, 07:57 PM   #2
DJ123
DJ123's Avatar
Default Re: K6 headlights not working at all?
Have you checked the fuse?
BMW F800ST
Old 24-10-13, 08:37 PM   #3
byron126
Yep checked the fuse and it still didn't solve the problem
Old 25-10-13, 06:52 AM   #4
DJ123
DJ123's Avatar
Have you checked the bulbs?
Have you checked the connectors on the back of them are pushed on far enough?
BMW F800ST
Old 25-10-13, 08:42 AM   #5
a_monkey_hint
There's a common fault with the connectors for the switchgear on either side. Take the front faring off and trace the switchgear to a large block connector - unplug and check there are no burns/markings. Douse in WD40.
Old 25-10-13, 08:03 PM   #6
fizzwheel
fizzwheel's Avatar
Moved to SV Talk
Old 25-10-13, 09:55 PM   #7
byron126
Appreciate the help guys, gunna have a go at it over the weekend see if I cant somehow get them to bloody work again
Old 02-11-13, 09:42 AM   #8
Toooldtodie
Toooldtodie's Avatar
That caused my "lights out" moment. Problem was traced back to the large block connector where the connections had corroded and been shorting for a while so had to be bypassed. Cow of a job, just had to start at the front and work back towards battery! Good luck, let us know if you sorted it and what the problem was, for future reference like.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 15-11-13, 06:30 PM   #9
MickeyHall
I had this problem this week, had a going over everything and gave up, went to the garage 4 hours £155 and two new looms later and she's fixed, I had a corrosion on the low beam down ner the air box and the high beam had corroded and burnt out by the connector block behind the speedo.
Old 18-11-13, 08:32 PM   #10
byron126
Bloody hell I hope that isn't the case with mine, i took it apart a little and took a look but it seemed fairly useless, no obvious problem with it so I'l probably have to end up at the local garage aswell
New Generation SV650 Headlights not working Runako SV Talk, Tuning & Tweaking 11 01-11-14 12:12 PM
Curvy headlights not working a_monkey_hint SV Talk, Tuning & Tweaking 25 21-09-13 12:49 PM
Curvy headlights not working. craig dow SV Talk, Tuning & Tweaking 40 06-05-12 07:14 PM
Main Headlights Stopped Working? Mej Bikes - Talk & Issues 12 13-02-10 11:12 PM
Headlights not working...HELP SHStroller68 SV Talk, Tuning & Tweaking 5 02-04-09 08:36 AM
