Old 29-10-13, 10:58 AM   #1
Balky001
Balky001's Avatar
Default Stripped thread - rear brake caliper
I was checking the bolts after changing my rear wheel and thought I'd check the rear pad retaining bolt was tight (not needed but as I was there....). The thread has been stripped. It can go finger tight but no more before twisting. The biek is a GSXR K7
So, change caliper, thread lock it or something else? Not sure I could get a helicoil in the caliper.....
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 29-10-13, 11:18 AM   #2
atassiedevil
Default Re: Stripped thread - rear brake caliper
If a helicoil won't work, its possible to go one size bigger and tap it out. Will require a bigger bolt, so it's a judgement call on if you wish to do this.....Also not sure what the space constraints are in there.
You could also get it filled with weld, then drill and re tap to original size. Depends how much messing around you want to do, and your budget.
Another caliper might be cheaper....
Old 29-10-13, 12:42 PM   #3
Do you have the single piston Tokico caliper?
Old 29-10-13, 03:09 PM   #4
Balky001
Balky001's Avatar
Hi Sid
Yes, that's the one. You thinking helicoil??
Old 29-10-13, 03:10 PM   #5
Balky001
Balky001's Avatar
I;m thinking another caliper from ebay might be cheaper (well, easier!!)
Old 31-10-13, 07:17 PM   #6
Yes. I've done exactly the same two or three times - how do people manage to strip that thread?
The wall is thin it's true, but there's no torque required so as long as you're careful it'll be fine.
Old 01-11-13, 12:39 PM   #7
Balky001
Balky001's Avatar
Thanks Sid. I was a bit worried damaging the caliper more by trying to get the coil in as it is so think as the pin point. But nothing ventured I suppose!
I know exactly how it was stripped as it was my mates bike!!!
Pointy rear caliper banjo thread size? Griffiths212 SV Talk, Tuning & Tweaking 0 18-08-12 02:50 PM
Curvy Rear Caliper Thread Question squirrel_hunter SV Talk, Tuning & Tweaking 7 21-06-12 08:41 AM
Yet Another Brake Caliper Thread Hardened Rider SV Talk, Tuning & Tweaking 9 14-01-09 12:28 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Front brake caliper thread insert replaceable ? SpankyHam SV Talk, Tuning & Tweaking 7 21-03-06 01:42 PM
