Old 01-11-13, 12:34 AM   #1
Default Swingarm bearings cheap. Pointy.
half price so get them while you can from Robinsons http://www.robinsonsfoundry.co.uk/co...18&submit.y=15
yes they are for a bandit but they fit the SV650 pointy 25x33x35
priced each so you'll need 2.
Old 01-11-13, 10:41 PM   #2
muzikill
muzikill's Avatar
Default Re: Swingarm bearings cheap. Pointy.
K3 650s?
Sent from my GT-I9505 using Tapatalk
Old 01-11-13, 10:48 PM   #3
yes all sv650 k3>
Old 01-11-13, 11:14 PM   #4
muzikill
muzikill's Avatar
Cheers bud.
Swingarm bearings - where from? granty92 Bikes - Talk & Issues 2 12-08-13 09:29 AM
Swingarm bobbin bolt stuck in swingarm BigV Bikes - Talk & Issues 7 12-06-13 12:24 PM
Sourcing swingarm bearings? Hornstar SV Talk, Tuning & Tweaking 27 17-03-12 03:16 PM
Removing swingarm bearings Demonz SV Talk, Tuning & Tweaking 2 18-09-08 08:01 PM
Reusign swingarm bearings? northwind SV Talk, Tuning & Tweaking 6 31-05-08 09:00 AM
