Old 11-12-13, 07:35 PM   #1
Mark-SV-UK
Default Pointy paint codes and headstock bearings?
Hi all.
1st question is would a 2003 pointy have the same paint code. My paint code is YAY NEBULAR 2009 k9 pointy
2nd question I have a little play innheadset bearings I think. Roughy how much would I expect a shop to charge to replace top and bottom headset bearings ????
Thanks guys and girls
Old 11-12-13, 09:15 PM   #2
Mr wilson
Default Re: couple of questions re paint codes and headset bearings
Hi Mark, can't help with the paint thing but as far as the headstock bearings are concerned I would think that an hour should be enough for that job, especially on a fairly new bike like yours. Wouldn't expect to come across too many seized bolts, bodged bits that needed sorting along the way etc. That said, are you sure its headstock bearings? Quite a new bike for them to be fecked unless its been to bits before for some reason. Might be play in the brake disc bobbins, calliper pins, or something like that? How are you checking them? Sorry, not doubting you, just thinking aloud.
Shug
Old 11-12-13, 09:37 PM   #3
Shawthing
Shawthing's Avatar
I thought K3s and SK3s only came originally in Blue, Silver and Copper!
So not Black, unless it had been resprayed and then it could be anything!
SK9 Sport Black Delkevic can.
Old 11-12-13, 11:30 PM   #4
Mark-SV-UK
Thanks guys the headstock clicks when pulling up at lights and when stationary with front brake applied and tryingnto move bike forward and backwards you can see a lil movement in headstock. Bike only had 2k when i bought it and was like new. Ive only done 8k since so 10k altogether.
QUOTE=Mr wilson;2923084]Hi Mark, can't help with the paint thing but as far as the headstock bearings are concerned I would think that an hour should be enough for that job, especially on a fairly new bike like yours. Wouldn't expect to come across too many seized bolts, bodged bits that needed sorting along the way etc. That said, are you sure its headstock bearings? Quite a new bike for them to be fecked unless its been to bits before for some reason. Might be play in the brake disc bobbins, calliper pins, or something like that? How are you checking them? Sorry, not doubting you, just thinking aloud.
Shug[/QUOTE]
Old 12-12-13, 01:46 AM   #5
Default couple of questions re paint codes and headset bearings
At that mileage they may not require replacement, only adjustment, the click when you stop would appear to confirm this, as such a noise is usually found with slack bearings, worn bearings usually give a notchy feeling to the steering.
Old 12-12-13, 01:48 AM   #6
Mark-SV-UK
Default Re: Pointy paint codes and headstock bearings?
Thanks mate will book it in to workshop when I can ride again
Old 12-12-13, 03:59 PM   #7
muzikill
muzikill's Avatar
Plus a re-grease before you do it.
Old 12-12-13, 04:14 PM   #8
Mark-SV-UK
Cheers ps whatbis normal price fornwork to be carried out roughly somenof you must have had this work done already?
Paint codes Gregson SV Talk, Tuning & Tweaking 6 25-05-10 08:19 PM
Paint codes MiniMac SV Talk, Tuning & Tweaking 4 07-07-08 08:59 AM
paint codes.. Pete_58 SV Talk, Tuning & Tweaking 22 22-05-08 04:05 PM
Paint codes John Ball SV Talk, Tuning & Tweaking 4 29-05-07 08:16 AM
a couple of questions re winter protection / paint steveg SV Talk, Tuning & Tweaking 1 29-10-06 09:33 PM
