Old 30-01-14, 01:08 PM   #1
CodeJACK
Default SV650S K3 Main loom
My K3 has finally had enough of the Datatool alarm that is fitted to it.
Looking for an unmolested loom for an unmolesting price
Would need to be shipped to Dublin.
Anyone know if a loom from a US K3 would work?
CodeJACK is offline   Reply With Quote
Old 30-01-14, 04:14 PM   #2
flymo
flymo's Avatar
Default Re: SV650S K3 Main loom
I may have one, will check.
Old 31-01-14, 12:42 AM   #3
CodeJACK
Default Re: Re: SV650S K3 Main loom
Great, I look forward to hearing back from you
Old 24-02-14, 01:29 PM   #4
CodeJACK
Bump...
Anyone?
Old 24-02-14, 03:02 PM   #5
hindle8907
hindle8907's Avatar
I have a k5 full loom don't know if that's any use ?
Old 25-02-14, 11:32 AM   #6
CodeJACK
Thanks for the offer but no, pretty sure it will not fit.
K3 was the only model with a specific loom that is longer/different to suit the higher rear subframe.
Old 29-03-14, 07:48 PM   #7
CodeJACK
Bump
Sent from my SM-T310 using Tapatalk
Old 31-03-14, 03:07 PM   #8
phil24_7
I would say the difference in length, if any, would be negligible as the rear subframe is not any longer. The only real difference is the bottom arm of the subframe is longer to make the rear end sit higher. All the wiring passes just under the top mounts.
SV650S wiring loom admin For Sale - SV's and SV related items 0 16-07-12 03:15 PM
SV650S K5 Injector Loom Frogman Stuff Wanted 1 06-04-11 02:11 PM
Main Connector for Clock on wiring loom broken. cbay SV Talk, Tuning & Tweaking 14 27-02-11 01:28 AM
Headlight Sub Loom SV650S 2001 Wanted NedSVS Stuff Wanted 3 05-07-08 09:39 PM
main fuse blows chaffing wire loom 1000homodjs SV Talk, Tuning & Tweaking 0 07-05-06 05:53 PM
