Old 18-02-14, 08:34 PM   #1
Default Gun users
As I know there are a few shooters on here, quick question regarding shotguns specifically, do you or is it safe to leave it cocked? I can't see why it would cause an issue but is there one?
Old 18-02-14, 08:38 PM   #2
ssray
Junior Member
Default Re: Gun users
would you leave your bike switched off with the throttle fully open?
ssray is offline   Reply With Quote
Old 18-02-14, 08:41 PM   #3
Totally different thing, so bad analogy.
Old 18-02-14, 08:43 PM   #4
ssray
Junior Member
by keeping a gun cocked you are keeping things under tension, same as if you kept the throttle open
Old 18-02-14, 08:48 PM   #5
Wideboy
Evel Knievel
Wideboy's Avatar
what kind of gun?
05 DRZ400E
RIP hovis
Old 18-02-14, 08:49 PM   #6
Why would you though?
Old 18-02-14, 09:00 PM   #7
Red Herring
Red Herring's Avatar
I'm also curious as to why you would want to? The only reason i can think of is if you anticipate needing it in a hurry, in which case you've probably loaded it as well......and if you're asking if it's safe to keep a loaded weapon cocked then you probably shouldn't be anywhere near it!
Old 18-02-14, 09:01 PM   #8
Teejayexc
Wait until you trip or fall whilst carrying a cocked gun, you'll soon find out!
Old 18-02-14, 09:04 PM   #9
Wideboy
Evel Knievel
Wideboy's Avatar
that's what the safety is for, i always have mine cocked if I'm using it.
I'm reading this as having it cocked for storage with nothing in the chamber.
05 DRZ400E
RIP hovis
Old 18-02-14, 09:06 PM   #10
Why would you?
Its like leaving the gas on and sparking up
Go Pro Users - HELP! M65 Idle Banter 7 14-01-13 12:03 PM
users map kwak zzr Idle Banter 26 08-02-06 06:02 PM
