Old 01-03-14, 04:58 PM   #1
Amadeus
Default Fluorescent lights
I have a fluorescent light in my garage and it no longer works (I think after power cut but couldn't be sure of that.
I've replaced the tube but it still fails to come on. I think the little capacitor (?) things need replacing - is that possible? Are they straight forward to replace - pull it out and out another in?
Thanks
Old 01-03-14, 05:02 PM   #2
Spank86
Default Re: Fluorescent lights
If its a strip light there ought to be a little cylindrical motor sticking out the side.
Push in, twist and it should pop out.
Could be that, although they usually go faulty slowly resulting in a light that takes ages to come on. You checked fuse boxes and stuff?
Old 01-03-14, 05:04 PM   #3
Red ones
Red ones's Avatar
If it's an old fitting - tube as big round as an inch, or even an inch and a half, then it's likely to be the starter.
Starters are dirt cheap and it's a straight forward swap to change it (just make sure you get the right size one to match the size of the tube)
If you have a newer electronic fitting it can be a little more difficult.
Don't forget it may just be the tube that's gone, not the starter. But I'd change the starter if the tube has gone - for the sake of 60p...
Old 01-03-14, 06:31 PM   #4
thefallenangel
Tube + starter. Although in work, I have now been fitting LED tubes with the mains straight onto the tube. So when it breaks in a billion years time it's only the tube.
If the choke has gone, more than likely the fitting will be scrap.
Old 01-03-14, 08:50 PM   #5
Starter by the sounds of it.
TBH if its a T8 fitting junk it and buy a T5 as they're end of life almost
Old 01-03-14, 10:49 PM   #6
Red ones
Red ones's Avatar
T5 isn't going to last much longer
Old 02-03-14, 10:02 AM   #7
Default Re: Re: Fluorescent lights
The manufacturers are saying about 10 years, as they're not developing the technology any further.
Going through lighting systems at work atm got a few which are end of life design
written with a brio
Old 02-03-14, 01:28 PM   #8
Amadeus
Thanks guys, sorry for the delay in responding. There were a number of reasons but the most significant one being that I'd not checked the fuse box... I have now and they're all good.
The old tube was an inch or so in diameter as suggested but the new one is much thinner.
I'll go and get a new motor thing and take the old one part this afternoon.
Thanks for the info.
Oh I suppose if it's not the motor either, it's a matter of getting an electrician in?
Thanks
Old 02-03-14, 02:28 PM   #9
Red ones
Red ones's Avatar
Fluorescent tubes are measured in 1/8th inch. A T8 is one inch diameter, a T5 is 5/8th inch diameter. If you had a T8 fitting it is likely to have been switch started with an induction starter and ballast, but the T5 is likely to need an electronic starter.
You could just take the tube back and change it for the right one, but to be honest in the long term you're better off getting a T5 fitting - soon you won't be able to get replacement T8 lamps, but the T5 tube is also typically 40% more efficient.
Old 02-03-14, 02:54 PM   #10
Amadeus
New motor fixed it - thanks guys.
Based in that success I'm considering setting myself up as an electrician now.
LED lights ruddlad Idle Banter 30 19-03-13 06:50 AM
Photos of SVs with fog lights or LED DRL lights? BradW314 SV Talk, Tuning & Tweaking 8 28-02-13 09:58 PM
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
MOT & Lights Demonz Bikes - Talk & Issues 21 23-09-08 11:49 AM
Fluorescent material personalisation? ooger Idle Banter 6 08-12-07 10:07 AM
