Old 01-03-14, 06:59 PM   #1
SharkyRider
Default Service advice? Curvy.
Hi guys, I decided to service my SV650SX 1999 this weekend and been having a problem finding a suitable coolant/anti-freeze for it and my other problem is getting the old oil filter off, it looks pretty old and I've used a strap remover but this ones on so tight it snapped it! I measured it at 66mm 14 flute
What I want to know is..
What type of coolant do I need
is 66mm 14 flute the right size for a cup wrench to remove it?
thanks
Old 01-03-14, 08:04 PM   #2
Ninthbike
Default Re: General service help
thanks
For the oil filter, buy the correct cup wrench with a 1/2" socket drive hole and you'll get it off no problem. You'll find one cheap on ebay. Best idea with coolant is to get the original manufacturer product then you should have no issues. It may cost a bit more but is the best idea in the long run.
Cheers.
Old 01-03-14, 09:56 PM   #3
wideguy
The cooling system on your bike is just like what's on a car. Any antifreeze that you would put in your car, you can put in your bike.
You can drive an old Phillips screwdriver or something similar through the filer and use that to break it loose.
Old 01-03-14, 11:27 PM   #4
Mikey360
+1, if you're replacing it anyway! I did this on an old scirocco once, worked a treat!
Old 02-03-14, 09:36 AM   #5
MJC-DEV
MJC-DEV's Avatar
Having a hot engine and oil make the filter come off a lot easier than with a cold one.
Halfords antifreeze is fine
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 02-03-14, 09:43 AM   #6
SharkyRider
Just tried this and how wrong. It didn't even break it loose just ripped the sides of the can open.
Old 02-03-14, 10:24 AM   #7
Tomor
Tomor's Avatar
Have seen it done many times. Drive the screwdriver through and use it as a lever to unscrew the filter
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 02-03-14, 10:31 AM   #8
DJ123
DJ123's Avatar
Default Re: Service advice? Curvy.
Both of the options you've tried should have got it to move. Maybe a daft question but are you turning it the right way? Get a pair of swan neck grips with a decent handle length, grip round the filter and turn. They will have no issue providing you do it right.
BMW F800ST
Old 02-03-14, 06:37 PM   #9
SharkyRider
I made a dent with a flat head screwdriver on the base and angled it counter-clockwise - loosened up much better than the screwdriver through the filter theory.
Thanks for those who replied with advice.
All service is done now, although I thought I'd get more help from this site.
Old 02-03-14, 06:53 PM   #10
Dipper
Dipper's Avatar
Not too sure you'll get more next time...
Dipper is offline   Reply With Quote
general used spares knocker99 For Sale - SV's and SV related items 5 24-02-13 04:24 PM
Service Manual for SV650S 2001 and Service Recommendation stone SV Talk, Tuning & Tweaking 1 09-05-07 04:20 PM
General LDV tricky Idle Banter 9 26-01-07 08:52 PM
Some general end-can questions Skiddy Exhausts 3 17-09-04 03:12 PM
Hi - general bike Q's Rizzy Rozz Idle Banter 17 08-01-70 08:06 AM
