Old 03-03-14, 11:21 AM   #1
BigV
Default Exhaust branches dull and grimmy - how to get shine back?
Hi all,
The exhaust branches coming from engine that go down and wrap under the frame, from all the riding etc...the chrome shine is completely gone. Besides taking off the whole system and sending to get redone...any DIY options to get the pipes back to their original shine?
Old 03-03-14, 11:30 AM   #2
Kenzie
Kenzie's Avatar
Default Re: Exhaust branches dull and grimmy - how to get shine back?
Metal polish and lots of elbow grease. Someone will pop along in a mo and list the best polish to use. It took me ages but well worth it.
Old 03-03-14, 11:43 AM   #3
BigV
Thanks & thats great, glad it's something a little elbow grease can fix, no problem! Yeah really want to sort it out...becoming a bit of an eye sore for me!
Old 03-03-14, 12:44 PM   #4
Shawthing
Shawthing's Avatar
Optiglanz or Autosol for Stainless.
SK9 Sport Black Delkevic can.
Old 03-03-14, 12:51 PM   #5
BigV
Thanks for that, will swing by the parts shop and pick some up
Old 03-03-14, 01:23 PM   #6
mep
mep's Avatar
+1 for Optiglanz. This will clean it up nice. You can use Autosol to keep it shiny.
mep is offline   Reply With Quote
Old 03-03-14, 01:39 PM   #7
SIII
SIII's Avatar
If it is really bad to start with use a fine grade wet and dry - 600, and lube with GT85 or wd40.
Then use autosol or similar to get a good shine.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 03-03-14, 01:48 PM   #8
BigV
Awesome! Thanks so much for the responses guys!
Old 03-03-14, 04:03 PM   #9
muzikill
muzikill's Avatar
A mirror to check it underneath to see how its looking. I had my exhaust off to rebuild the engine and did it then.
Caterham branches out to launch motorcycle division NewsBot News 0 05-11-13 11:30 AM
Caterham branches out to launch motorcycle division NewsBot News 0 05-11-13 10:00 AM
Looking for some fruit tree branches Ajwou Idle Banter 1 03-07-13 07:46 PM
Restoring dull paint on plastics & metal? SUPERSTARDJ01 Bikes - Talk & Issues 1 04-11-09 08:35 PM
Really dull question........help me o wise org! Davies Idle Banter 1 14-11-08 12:17 AM
