Old 13-03-14, 07:16 PM   #1
PuggledPrune
Default Caliper rebuild - how?
After a few Scottish winters, the SV's brakes were in serious need of a refurb.... Have taken the calipers apart to clean everything but the rubber bits split so have ordered a kit with replacement seals and rubber bits...
Just wondering if someone could point me in the direction of a wee guide to putting the seals on etc....
TIA.
Old 13-03-14, 08:50 PM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: Caliper rebuild - how?
Haynes Manual?
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 13-03-14, 09:03 PM   #3
PM me you email & I'l send you the Suzuki PDF for servicing the caliper
Old 13-03-14, 09:18 PM   #4
TheRuffellator
Default Re: Re: Caliper rebuild - how?
Sorry to be a pain but would you be able to send me a copy too? As I'm going to rebuild my calipers at some point soon and it would be helpful
Old 13-03-14, 09:42 PM   #5
No problem, pm me your e-mail
Old 13-03-14, 10:40 PM   #6
TIA.
even better, how about i come up and show you how to do it properly.
i'm free next sunday morning.
Old 14-03-14, 07:40 AM   #7
Broom
There's a guy on youtube who is an ex-mechanic. His youtube name is Moonfleet41 and he has a video called delboy's garage - caliper rebuild. He has a few how to videos on his channel that I found very useful. Perhaps check out his video.
Old 14-03-14, 12:04 PM   #8
Jayneflakes
Jayneflakes's Avatar
I did a Youtube video on this subject a short while ago, but it was more instructional on swearing than mechanics.
YouTube Video
Not sure if it will help you, but you never know.
Jayne you're a Pussy Magnet
Old 14-03-14, 12:41 PM   #9
TheRuffellator
Cheers mate will send it over now
Old 14-03-14, 02:18 PM   #10
muzikill
muzikill's Avatar
Is that in the 'normal' bootlegged suzuki workshop manual?
Bandit 600 Rear caliper rebuild Kenzie Bikes - Talk & Issues 2 10-08-11 06:56 PM
caliper rebuild help???? arcdef Guildford Massive 13 04-01-09 08:28 PM
help with caliper rebuild?? arcdef Thames Valley 3 04-01-09 05:36 PM
caliper rebuild sv_rory SV Talk, Tuning & Tweaking 42 14-12-08 12:40 AM
Caliper Rebuild Kits and Pad Pins Xtrac SV Talk, Tuning & Tweaking 13 24-02-05 07:56 PM
