Old 23-03-14, 09:01 PM   #1
Kenzie
Kenzie's Avatar
Default Gopro straight joint
Does anyone know where I can get a Gopro joint like this:
http://www.thingiverse.com/thing:123878
All of the joints I see online rotate every time you use one and make it longer than it needs to be. I have a mount on my tank and just want to raise the camera up about an inch. I have seen them as part of a front head mount but I don't want to buy one and find it is wrong.
Old 23-03-14, 09:24 PM   #2
Default Re: Gopro straight joint
Have a look on amazon, if they don't do it, nobody does.
Old 23-03-14, 09:36 PM   #3
Kenzie
Kenzie's Avatar
Already have done. Only seems to be part of the front mount. Anyone on here got a 3D printer?
Old 23-03-14, 09:43 PM   #4
Can't you buy this and just use the one part?
Sports Camera Handlebar Seatpost Rack Mount Bicycle Holder Bracket Compatible Gopro HD hero 2 3 http://amazon.co.uk/dp/B00DKSYCN0
Old 23-03-14, 10:16 PM   #5
Tomor
Tomor's Avatar
Kenzie wants an extender that doesn't rotate the camera 90 degrees.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 23-03-14, 11:34 PM   #6
You should easily be able to concoct something using a couple of small ones maybe, by leaning it back to lose the height if two mounts together make it too high, it's hardly complicated.
Old 24-03-14, 07:01 AM   #7
Kenzie
Kenzie's Avatar
I have tried this with the smaller joints, however putting two together allows the camera to vibrate a bit. I will try it again with two of the shortest ones but I would prefer to do it with one piece.
Old 24-03-14, 08:54 PM   #8
Kenzie
Kenzie's Avatar
Figured it out. I will just use a new sticky mount on the tank but stick it 90 degrees to how it is now (across the bike instead of front to back) then the joint will rotate the camera straight again.
Removing from joint mortgage Bluefish Idle Banter 14 03-02-12 11:22 PM
Pattern exhaust joint gaskets? tonny006 SV Talk, Tuning & Tweaking 6 21-01-09 10:24 AM
Anyone know how to fix a rose joint? Bear SV Talk, Tuning & Tweaking 16 30-10-07 07:40 AM
Joint bank accounts rubberduckofdeath Idle Banter 13 18-01-07 04:28 PM
