Old 24-03-14, 11:22 PM   #1
DickySv650s
Default Pointy won't go above 3000rpm.
Hi Guys.. Recently Bought A Sv650s 2005..
Its Been Fine Untill Today.. Parked Outside My Mates This Afternoon As I Was Leavin About Half A Mile Into My Journey Bike Started Struggling To Rev And Want Rev Over 3k.
Checked All Connections.. Changed Plugs & Still Same Problem..
Help Needed Please Guys.. Thank You In Advance
Old 25-03-14, 09:12 AM   #2
Aquila
Default Re: Pointy won't go above 3000rpm.
Possibly an electrical sensor!
Old 25-03-14, 10:23 AM   #3
Red Herring
Red Herring's Avatar
When you switch off, then back on again do you get any warnings on the dash?
Do a search on here on how to read the fault codes (really easy, all you need to do is find the right plug under the seat and use a paper clip to bridge two connections)
Old 25-03-14, 10:54 AM   #4
DickySv650s
Thanks Mate.. I Will Go Check That Now
Old 25-03-14, 01:04 PM   #5
muzikill
muzikill's Avatar
Isnt the 3k a limiting safegard due to a error?
Sent from my GT-I9505 using Tapatalk
Old 25-03-14, 02:42 PM   #6
Red ones
Red ones's Avatar
FI light on when it happens?
Is it, by any chance, raining?
Old 25-03-14, 08:02 PM   #7
DickySv650s
Sorted Guys..
Old 25-03-14, 08:06 PM   #8
Red ones
Red ones's Avatar
What was it?
Old 25-03-14, 08:25 PM   #9
DickySv650s
Unsure.. There Was No Error Codes Showing.. Bur Ive Cleaned All Connections.. Plugs An Plug Caps.. Cleaned Fuel Pump And Filter.. Now She Starts Fine
Chugging at 3000rpm curvy bert682 Bikes - Talk & Issues 4 20-04-12 05:24 AM
Swap a set of Pointy wheels for a Silver Pointy front wheel Berlin For Sale - SV's and SV related items 4 13-03-11 07:35 AM
Naked Pointy brake lever fit Faired Pointy? tj ready SV Talk, Tuning & Tweaking 2 09-07-10 07:37 AM
HELP K4 3000RPM vroooOOOM SV Talk, Tuning & Tweaking 2 26-12-04 10:50 AM
