Hi Guys,
I'm in the process of fightering my curvy and wanted to put on some bandit clocks, now because the speedo on the SV is not cable, would it be possible to put the clocks from a 2001 Bandit on if wired up ok and would they work pretty much spot on. Heres an ebay link to some i am currently watching. http://www.ebay.co.uk/itm/1612464495...84.m1423.l2649 Thanks in advance. Si |
Check the fiche to see if the speedo drive is the same - if yes they'll work fine. If not you need to find out how many pulses per rotation the Bandit uses, if the same as the SV no problem.
I've got mk1 Bandit 600 clocks on mine. Everything works fine except the fuel warning light. The speedo drive is fine too. Not sure if everything would be OK with the mk2 bandit clocks you are looking at.
Here's what mine looks like - a few posts down. http://forums.sv650.org/showthread.php?t=202460 |
smart, i really fancy keeping the SV speedo drive if possible thats why i was looking at the mk2 clocks, time to do some research i guess
Curvy naked clocks glass or complete clocks. | ejohnh | Stuff Wanted | 1 | 25-03-14 06:54 PM |
Bandit clocks on a 99 SV650? | Badeye | SV Talk, Tuning & Tweaking | 3 | 13-02-14 12:58 PM |
Bandit clocks on sv ? | pete sv | SV Talk, Tuning & Tweaking | 1 | 13-02-11 02:43 PM |
K3 clocks on a curvy? | artfull_owl | SV Talk, Tuning & Tweaking | 8 | 24-06-08 07:54 PM |
For Sale: Suzuki Bandit 2001(Y) | Viney | Idle Banter | 0 | 09-06-08 09:37 AM |
