Old 16-04-14, 09:11 AM   #1
sputnik
Default Old fork oil - different colours?
I changed my fork oil at the weekend and was a bit surprised when the old contents of each fork were completely different colours - one fork's oil was a sludgy grey liquidised brain kind of colour whilst the other's was a sludgy reddish brown evil curry sauce sort of colour. They also both (mostly) stayed separate from one another in the oil tray I poured them into.
Googling suggests this is not an entirely uncommon finding but I couldn't find much to explain why. The main theory I saw is that the factory put different types of oil in each fork (possibly even different grades). This would seem to be an obvious answer but it sounds a tad unlikely to me. Anyone know the answer?
Old 16-04-14, 09:42 AM   #2
TamSV
TamSV's Avatar
Default Re: Old fork oil - different colours?
Maybe it had a leaking fork seal at some point in the past and only the affected fork leg was dealt with. So could maybe be original oil in one leg and newer stuff in the other.
Old 16-04-14, 10:02 AM   #3
sputnik
Can't say with absolute 100% certainty but I am 99% sure this is the first time the forks have been off the bike since new. Bike was just over a year old when I bought it with 3k on the clock so wouldn't have thought it would have had any fork work done in that time.
Old 16-04-14, 02:20 PM   #4
rust...
Old 16-04-14, 02:25 PM   #5
Water contamination changes fork oil into weird colours and smells.
Old 16-04-14, 06:33 PM   #6
sputnik
I wondered about that. And rust. Although the spring etc all looked to be ok with no obvious signs of corrosion. I confess to not really knowing what lurks at the bottom of the forks!
Anyway, here's a piccy of my multi-coloured gloop, for your viewing pleasure...
Old 17-04-14, 07:10 AM   #7
muzikill
muzikill's Avatar
... and think of the amount of bikes where no one has changed the oil!
Sent from my GT-I9505 using Tapatalk
Old 17-04-14, 09:00 AM   #8
PyroUK
PyroUK's Avatar
Attachment 13807
As disgusting as that is from a functional point of view, it is actually quite pleasant to look at. Like one of those sand landscapes you get down the beach.
Maybe you can sell it was a bit of modern art?
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 17-04-14, 09:15 AM   #9
Sir Trev
Sir Trev's Avatar
That block paving could do with a clean... [/derail]
Old 17-04-14, 09:18 AM   #10
Yeah that's normal, like sid says water and oxidation of the oil from seal leaks.
Reason you don't get rust inside is oil is designed to stop it. Emulsifier additives etc.
Colours for 09? blankslate Bikes - Talk & Issues 0 21-04-10 12:52 AM
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
K6 colours???? quikstu Photos 4 03-06-06 08:31 PM
RSV colours Demonz Bikes - Talk & Issues 7 07-05-06 07:46 AM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
