Old 25-04-14, 08:17 PM   #1
byron126
Talking Side panel bolts + Tank bolt (Pointy)
Does anyone have and spare side panel bolts for a pointy? I'm referring to the two 4mm allen head bolts that go into the two black plastic bits that go either side of the tank or if anyone knows the size of the thread of these bolts so i can order a pack from somewhere. Also stripped the tank pivot bolt out recently and was wondering if anyone knew again what size this bolt is? Sorry about the unspecific post guys but as always any help is appreciated
Kind Regards
Byron.
Old 28-04-14, 08:33 AM   #2
atassiedevil
Default Re: Side panel bolts + Tank bolt (Pointy)
Toolstation, M5 stainless.
http://www.toolstation.com/shop/Scre...0/sd810/p32632
They have an entire range of these, so quite useful for prettying things up on the cheap.
Old 02-05-14, 11:48 PM   #3
Kind Regards
Byron.
For the bolts that hold the two black diamonds on, you are better to just order them from Suzuki, as they have a non-threaded shoulder that stops you from over tightening the bolt and snapping the plastic. They are definitely not 4mm
Side panel bolt size query? Dfraser76 SV Talk, Tuning & Tweaking 8 06-02-15 06:57 PM
Pointy Side stand bolts? to affix fairing to Mark-SV-UK SV Talk, Tuning & Tweaking 22 23-02-13 12:10 PM
Side panel bolts (under the seat) where from? theCave SV Talk, Tuning & Tweaking 10 10-12-12 04:26 PM
Seat panel bolt - Pointy DarrenSV650S SV Talk, Tuning & Tweaking 12 09-06-11 11:19 PM
Right hand side rear fairing/tail light panel - pointy Nobbylad Stuff Wanted 3 22-09-09 11:22 AM
