Looking for a rear brake lever, and indicators.
Woke up early yesterday, was parked in a crappy place so I used the disc lock, forgot about it in the morning when going to pull away and down on its side it went. Front right indicator specifically, would purchase a pair for the front if it still works out cheaper than buying new. Last edited by LiquidFlux; 28-04-14 at 11:40 PM. |
Depending on how bad the indicator is you can probably super glue back together and nobody will notice.
Its what I did and you can barely tell.
Naked K5 - Now Red with sexy stripes!! Mods: Renthal Flat bars, 's' clutch perch, GSXR front master cylinder, CNC shorty levers, Tail Tidy, Fuel Mini S/S Slip-on, 15/47, 's' Swing-arm, Pillion seat cowl, GSXR 750 front end, CNC polished top yoke, R6 Throttle tube, GSXR rear shock |
It split into multiple pieces, and then a bus ran the lens and fragmented bracket over.
Thanks for the suggestion though. |
Ah, that's rubbish.
I'm due to be fitting some LED indicators as soon as I get a dry day at the weekend so will have the OEMs (Orange lenses) laying around so you can probably have one of the intact one of those when I get round to it, unless somebody else has one they can provide sooner. J
Lovely offer, but I need the black frame bracket around it too.
Do you need a resistor with an LED kit? |
Not sure what you mean by the bracket. Part number off these diagrams: Faired, Naked (I forgot to ask which yours was)?
For LED indicators you will either need resistors or a different relay. I have a suitable relay in at the moment (works for bulbs and LEDs) from ebay (this one). J
Yeah, 9-10 in the diagram you linked.
Will investigate the LED stuff, thanks. |
Oh, I see what you mean now.
When I said I will have some indicators laying about in the future I did mean the whole assembly. I mentioned orange lenses as some later bikes have clear ones, not that I would only have the lenses. You may prefer the LED stuff anyway. Best of luck. ![]() J
#9 |
If you've the entire assembly, I'd very happily pay for them.
Any idea when you'd have it ready? I've a functioning bulb at the moment, but it's free hanging. |
#10 |
At the moment I don't know. Whenever I get off my backside when it' dry.
Hopefully do it at the weekend but might not get round to it. I'll let you know if I manage it at the weekend. If you manage to sort yourself out before then, no worries. J
rear brake lever sv1000 /pointy indicators /db screen | davepreston | Stuff Wanted | 7 | 22-10-10 03:35 PM |
RH Footpeg Hanger, Rear Brake Lever and Clutch Lever for 2004 Naked Wanted | Drumming_Animal | Stuff Wanted | 0 | 26-07-10 10:52 PM |
Curvy brake lever & rear brake pedal | Old Git | Stuff Wanted | 1 | 09-01-10 11:00 AM |
WTD - rear brake lever, front brake lever, r & G crash bung, | nik_nunez | Stuff Wanted | 0 | 17-10-08 08:27 PM |
Gear lever as rear brake lever? | plowsie | SV Talk, Tuning & Tweaking | 2 | 29-05-07 05:23 PM |
