Old 05-05-14, 01:03 PM   #1
LoveApples
Default Problem with 2007 pointy speedo
I was on my way back from a ride at the weekend and I noticed my speedo was having a bit of a laugh with me. I was doing around 30mph but the speedo kept jumping to anything from 103mp to 27mph for no reason.
Has anyone had this problem before, if so how did you manage fix it?
Any help would be appreciated.
Cheers!
Old 05-05-14, 01:13 PM   #2
Purity14
Default Re: Problem with 2007 pointy speedo
I have had this before, ended up being a loose battery terminal.
Not enough to affect anything else but the speedo.
Old 05-05-14, 01:29 PM   #3
had your tyres change recently?
Old 05-05-14, 03:43 PM   #4
LoveApples
@Purity when I've checked the positive terminal was a bit loose so I've tightened that up.
I haven't had the tyres @Bibio. I might have hit a pot-hole which could have knocked the sensor?
I'm just about to go for a run around the block to see if tightening the terminal has helped.
Thanks for your suggestions.
Old 06-05-14, 09:52 AM   #5
LoveApples
Tightening the connection on the battery worked a treat.
Thanks for your help.
Old 06-05-14, 11:55 PM   #6
Heorot
My speedo did the same after a minor drop when some c*nt in a people carrier cut across me and I had to take avoiding action. Turns out that I had cracked the plastic rotor that's part of the speed sensor.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 07-05-14, 02:25 PM   #7
Purity14
Yeah it is usually one of the two answers that either I or Bibio gave.
Glad you are sorted
SK7 Speedo Problem v0r73x Bikes - Talk & Issues 5 17-07-13 12:34 PM
idle problem on sv650 2007 massacus Bikes - Talk & Issues 0 07-10-12 10:37 AM
idle problem on sv650 2007 massacus Boots 0 07-10-12 10:17 AM
SV650S-K3 Speedo failed (random numbers) - Rotor seems OK, speedo drive problem? Tallguy SV Talk, Tuning & Tweaking 4 25-05-12 12:38 PM
Speedo problem. Giggsy SV Talk, Tuning & Tweaking 11 19-02-09 06:13 PM
