Hi, I dropped the bike and the gear shifter peg snapped off from the main lever, as it is meant to do ,I guess. Did I see on here somewhere that someone provides replacements that can be bolted on after the old bit has been drilled out ?
John T
I drilled a hole tapped it and then used a spare bolt.
You might be thinking of this http://www.visordown.com/motorcycle-...onds/6083.html sent via Pony Express
Admin for this forum and the main site. John@sv650.org Last edited by admin; 25-05-14 at 10:09 PM. |
Thanks for reply, that's what I will do, cheers
DONT I SAY AGAIN DONT BUY THE MOTRAX VERSION
or the org will turn on you like 2 month old milk hth DP |
John T
My bolt bodge was meant to be a temporary fix but worked as well as the original so I left it. I even had the rubber attached.
![]() sent via Pony Express
Admin for this forum and the main site. John@sv650.org Last edited by admin; 26-05-14 at 08:57 AM. |
Just remember when you remove it to put it back on the right way round. Unless of course you want race gearing (1 up 5 down.)
Sent via the medium of interpretative dance. |
I can also confirm the bolt repair works a treat having had it on the bike for approx. 17k miles.
J
Naked K5 - Now Red with sexy stripes!! Mods: Renthal Flat bars, 's' clutch perch, GSXR front master cylinder, CNC shorty levers, Tail Tidy, Fuel Mini S/S Slip-on, 15/47, 's' Swing-arm, Pillion seat cowl, GSXR 750 front end, CNC polished top yoke, R6 Throttle tube, GSXR rear shock |
Yep
Gear shifter spindle | Fozzy | SV Talk, Tuning & Tweaking | 9 | 26-06-12 02:04 PM |
Desperaley need a k6 gear shifter | joshwalker094 | Stuff Wanted | 15 | 19-12-11 09:38 AM |
Curvy gear shifter | JamesMio | Stuff Wanted | 3 | 28-02-11 05:21 PM |
Goodby Gear shifter :( | hob | SV Talk, Tuning & Tweaking | 7 | 18-11-08 05:29 PM |
Gear shifter linkage rod | Razor | SV Talk, Tuning & Tweaking | 5 | 05-01-07 11:26 PM |
