Old 06-06-14, 05:02 PM   #1
zxmark9r
Default Clarke CIR13C 1/2" Impact Wrench Kit (12V)
Bought one of the above recently, as I was unable to get the front sprocket bolt of my wifes SV650. I had tried to do it with a 20” torque wrench, but it just wouldn’t budge.
A few second was all it took with this 12v impact wrench.
I don't know how robust it would be for heavy/prolonged use, but for this job it was fab.
Highly recommended.
Mark
Old 06-06-14, 06:57 PM   #2
admin
John T
admin's Avatar
Default Re: Clarke CIR13C 1/2" Impact Wrench Kit (12V)
I've got something similar that I bought from Aldi. Well worth having. I think I only paid about £15 for it.
sent via Pony Express
Old 06-06-14, 07:09 PM   #3
You tried to undo a hard to undo nut with a torque wrench? They are not designed for that.
A 24 inch breaker bar will crack most nuts.
Old 06-06-14, 07:43 PM   #4
admin
John T
admin's Avatar
Default Re: Re: Clarke CIR13C 1/2" Impact Wrench Kit (12V)
I used to struggle with sprocket nuts even using extended bars. I used to go to the local bike shop and use their air hammer to loosen stubborn nuts. The tool I have now is much the same thing but 12v powered
Old 07-06-14, 03:38 PM   #5
SIII
SIII's Avatar
Quickest way to ruin a torque wrench is using it as a breaker bar - oops! Looks like you need to save up for a new torque wrench.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 07-06-14, 05:50 PM   #6
zxmark9r
The torque wrench is good for 230nm the sprocket nut is set to 145nm, so I don't think it would have damaged it!
Old 07-06-14, 05:55 PM   #7
Yeah but for tightening, releasing stuck nuts will often see an initial release torque of way beyond the spec for the nut.
Breaker bars are for cracking nuts (or that impact wrench you bought).
Old 07-06-14, 06:09 PM   #8
Winder
Winder's Avatar
I got one of those little impact wrenches to get seized damper rod bolts out of my old bike forks. Worked a treat
OMO: Which impact wrench DarrenSV650S Idle Banter 23 04-12-12 11:34 AM
Clarke 37" wood lathe for sale. Specialone Idle Banter 3 05-03-12 06:02 PM
For Sale: 1/2" Impact gun a.oneill45 For Sale - Other Bikes and General biking items 6 28-12-10 10:31 PM
