Old 30-06-14, 03:59 PM   #1
aesmith
Default Rapid, uneven rear pad wear
Hi,
I've just had to replace the rear pads after only about 6 or 8 months (say no more than 7,000 miles). Two things strike me, firstly that seems a very short life, what sort of mileage to others get? Every time I've checked the wheel turns freely with no binding, also checked by feeling the disc after a journey and it's never more than very slightly warm.
The other thing is that the pad wear is not even, the pad on the piston side is much more worn than the other side. It seems to me that this means the caliper isn't sliding properly, but I can't feel anything binding when I removed and refitted the caliper. Could there be something worn that means the caliper feels free to slide, but doesn't actually do so in real use?
Pointy S K6.
Thanks, Tony S
Old 30-06-14, 04:11 PM   #2
Nutsinatin
Nutsinatin's Avatar
Default Re: Rapid, uneven rear pad wear
Depends how much you use your rear brake but I replaced my rear pads when they fell apart, was nowhere near wearing them out (they had been in the bike for 5 years so 28,000 miles with 20,000 of those being me in the last year).
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 30-06-14, 06:00 PM   #3
NTECUK
NTECUK's Avatar
JP used to muller his pads looked at loads of times.
When he got it mot test they failed the stop light of the rear brake.
Next weekend when you followed him he road with the foot just resting on the back brake!
I didn't take the rise..... Much lol
Old 30-06-14, 06:04 PM   #4
NTECUK
NTECUK's Avatar
Originally Posted by aesmith View Post
Hi,
Thanks, Tony S
Check out the side play on the axle.
Spacers and incorrect fitting of calipers and there mounts does happen
Old 30-06-14, 07:33 PM   #5
Tony
Yours is a curvy?
Old 01-07-14, 11:32 AM   #6
aesmith
Tony
Yours is a curvy?
Pointy.
I think NTECUK may be on to something. I'll check the spacers/washers on the back.
Tony S
Old 01-07-14, 12:07 PM   #7
what make of pads did you fit?
Old 01-07-14, 01:35 PM   #8
aesmith
The pads that have just worn out were EBC GG.
Old 01-07-14, 02:05 PM   #9
keith_d
keith_d's Avatar
When you fitted the new pads was it relatively easy to slide the pistons back into the caliper? If one of them was sticking it could result in the pads resting on the disk.
Old 01-07-14, 02:06 PM   #10
those should last 20k+ miles.
if its just the piston side then i would suspect that your calliper needs a proper service.
Rapid clutch wear ophic SV Talk, Tuning & Tweaking 27 23-06-14 11:28 AM
Uneven brake pad wear andrewsmith Bikes - Talk & Issues 10 16-05-12 09:06 PM
Uneven Tyre wear Jayneflakes SV Talk, Tuning & Tweaking 10 12-07-11 01:21 PM
Uneven chain wear rockster SV Talk, Tuning & Tweaking 17 16-05-09 08:03 PM
Uneven wear.. StreetHawk Tyres 5 29-04-07 09:42 PM
