Old 07-07-14, 09:24 AM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Default engine de-coking solution
I'm wanting to clean out the intakes on my van which have had 50k of egr cack chucked through them and was wondering if anyone had any suggestions on anything that could assist with stripping the crap off.
Any suggestions?
05 DRZ400E
RIP hovis
Old 07-07-14, 09:48 AM   #2
jambo
jambo's Avatar
Default Re: engine de-coking solution
I have no experience de-coking anything that isn't already in bits.
I've seen services such as TerraClean touted on shows like Wheeler Dealers for this kind of thing, but whether it represents value for money I couldn't say having never used it.
Jambo
Old 07-07-14, 10:03 AM   #3
Wideboy
Evel Knievel
Wideboy's Avatar
I'm going to take all of the induction system off right back to the engine block so I can get in there with a wire brush and spray whatever all over it to help the crud come away a bit easier. I was thinking brake cleaner might do a good job?
05 DRZ400E
RIP hovis
Old 07-07-14, 10:05 AM   #4
Spank86
Bicarbonate of soda.
Well, it works for two stroke exhausts anyway.
Old 07-07-14, 10:23 AM   #5
punyXpress
punyXpress's Avatar
. . or, if not alloy, ( which they probably are ) caustic soda.
Now: Street Triple R
Old 07-07-14, 10:57 AM   #6
NTECUK
NTECUK's Avatar
Carb cleaner spray.
Be cautious it don't end up getting sucked in the engine heater plugs out and turn it over by hand first before you get any chance of hydraulicing the piston
Old 07-07-14, 12:06 PM   #7
Spank86
That could well be what I was thinking of.
It's been a while since I had a two stroke (ooh er).
Old 07-07-14, 02:14 PM   #8
_Stretchie_
Large Member
_Stretchie_'s Avatar
Jambo
I was going to mention this too. It's about £100 or it was when I enquired about it, they said they do cars, bikes, vans whatever.
How to amuze an idiot:
Look right-> <-Look Left
Old 07-07-14, 11:04 PM   #9
Is it a diesel? If yes then Terraclean will not clean the intake or EGR, it is connected to the fuel system and as such the cleaner will pass through the pump, lines, injectors and cylinders. The intake of a diesel carries only air - and the cylinder blowby, oil mist etc that enters the intake from the crankcase vents, which is what makes up the majority of the crud you'll find clogging the EGR/intake manifold/intercooler/etc depending on where exactly the vent's plugged into the intake system.
Old 07-07-14, 11:16 PM   #10
Red ones
Red ones's Avatar
GM diesels do recirculate exhaust gases and deposit soot in the intake, as do BMW.
The difference is when BMWs clog it is often the end f days for the vehicle. For GM engined cars is can be an expensive repair.
If poss clean it with carb cleaner but do let the cleaner to drain off and evaporate.
Keep the intake clean, if you don't you can be looking at repairs to the swirl flaps and if not treated also problems with the DPF.
CRT solution? Spank86 Moto GP 4 28-10-12 04:28 PM
Yo Scoobs, might have a solution to your 'Problem' _Stretchie_ Idle Banter 9 11-08-10 05:28 PM
Solution for rusted bolts? suzsv650 Bikes - Talk & Issues 44 19-03-09 10:17 PM
The Solution: SV650.Org gettin2dizzy Idle Banter 5 18-12-07 04:52 PM
My Bullet Cam solution 2mths Bikes - Talk & Issues 48 06-07-07 12:03 PM
