Old 10-07-14, 06:50 AM   #1
ManMango
Default Pointy (K5) small crack in fairing
I want to get this repaired, I was thinking a DIY job would probably do the trick. Shot term main concern is I don't want it to get bigger! If I want to make it look prettier in the long run that can come later. Just getting it fixed solid is priority!
Has anyone here ever repaired such a crack or got it repaired at a shop and how much did this cost if done by a professional?
Old 10-07-14, 07:57 AM   #2
NTECUK
NTECUK's Avatar
Default Re: Pointy (K5) small crack in fairing
If you are happy to remove it ,then do this after practicing on somthing scrap
http://www.rubbermat.myby.co.uk/fair...ringRepair.htm
Old 10-07-14, 03:22 PM   #3
SvNewbie
I don't know if anyone has ever tried re-enforcing a fairing using this technique, might be a bit tricky if the area is a little flat but its interesting none the less.
http://woodgears.ca/misc/plastic_repair.html
Old 10-07-14, 03:50 PM   #4
for reinforcing i melt pipe gauze into the plastic. after welding up the crack using plastic weld rod or cable tie heat the gauze and then drop it onto the part you want to reinforce. finish the job by laying some fibreglass on top.
Crack in fairing - repairable or not? Pricey12 SV Talk, Tuning & Tweaking 6 19-04-13 04:05 PM
Small crack in tyre. slark01 SV Talk, Tuning & Tweaking 8 21-08-09 04:32 PM
Small scuffs / marks on fairing - can T-Cut out? Wayluya SV Talk, Tuning & Tweaking 3 07-08-08 10:50 AM
Fitting lower fairing S k5 - just a small question... Paul the 6th SV Talk, Tuning & Tweaking 3 27-01-08 11:34 PM
Fixing a crack in Fairing? Jaqui_uk SV Talk, Tuning & Tweaking 2 19-04-06 11:35 AM
