Hello all, part of my drive is paved with patio slabs, and two are rocking. Can anyone advise me how to fix this?
Tia Scotty |
#2 | |
Hahahaaa😅
If there aren't any dead bodies of course, just lift the slabs and throw some sand down.
Sent via the medium of interpretive dance. |
I thought this was the morgue-inspired name of your new prog metal band with overtones of magic realism and acid skiffle. So I was going to suggest a mosh pit, edible bats, inflatable skeltons, 14,000,000 pyrotechnic blunderbiii (which I think is the plural of blunderbus), and a backing tape consisting mainly of the brown noise.
but it isn't Lift slab, scrape out a couple of inches of muck, replace with either mortar or a mixture or ballast and cement in the same ratio (4:1 ish) - can be a dry mix. carve a cross in it witht he trowel (no kidding) and put it back down and stamp level. If you put too much muck under it then it'll rock again, the cross shape gives it space to squidge around. Leave to set for a day or two and say a few Hail Marys for good measure |
keep it how it is and play air guitar when it rocks.
Thanks all, especially you bib
Depending on the exact circumstances, sometimes you can solve the problem simply by sweeping in some kiln dried sand. This will find its way into the gaps under the corners/edges which allow the rock. Make sure the weather is dry for a day or 2 before you do it so it doesn't wet and clog as soon as it hits the gaps.
Of course this isn't a guaranteed fix for really badly laid slabs, but I've fixed a couple of patios with lots of mildly rocking slabs like this. I always explain how likely it is to fix or not, but it's very quick and cheap to try, and if it works it saves a huge amount of work lifting/clearing/re-laying.
#9 |
Lift all existing paving, excavate to at least 400mm. Fill with 300mm crusher run, in 100mm courses, using a vibrating plate for each course. Bind with at least 25mm grit sand, using vibrating plate. Lay further 75mm grit sand and screed to level. Re-lay paving and use vibrating plate with rubber cover to 'bed' down. Fill joints with kiln dried sand or dry sand/cement (4:1), brushed in.
Or just lift the wobbly ones and put some grit sand down to level them off. |
#10 |
Here's my two penneth...
Lift offending slabs, dig all old crap out of at least 40mm, get some sharp/concreting sand, building sand, cement and some plasticiser. Mix at a ratio of 6 sharp, 4 building and two cement, make it like thick cream, lay a full bed down, but get the level about 5-10mm higher than where the bottom edge of the slab should be, but with a trowel create a few lines for it to spread out when the slabs are relaid and tapped down. Tap down the slab gently, use a block of wood and a hammer to tap it down to required level. |
sv650 and sv1000 bits for sale ( inc the flying rocking horse poo naked bits) | davepreston | For Sale - SV's and SV related items | 10 | 22-04-14 01:41 AM |
Undamaged Curvy top fairing (aka Rocking horse poo) | benji106 | Stuff Wanted | 1 | 16-04-13 09:04 PM |
Rocking horse poo | svrash | For Sale - SV's and SV related items | 3 | 05-08-08 08:51 AM |
Rocking horse poo AKA gel seat for a curvy | dirtydog | For Sale - SV's and SV related items | 1 | 13-03-07 12:15 AM |
