Old 21-07-14, 08:28 AM   #1
Dalerst
Default Pointy S bar conversion?
Has anyone done a bar convertion on a points s? If so can you tell me which cables i will need to change and what bike you got them from. I'm looking at doing mine. I will be buying the cnc rises and my own bars so just need to know which cables i need. Or if they can be re routed. Cheers
Old 21-07-14, 08:52 AM   #2
Jayneflakes
Jayneflakes's Avatar
Default Re: pointy S bar convertion
I used the clutch cable from a DL650 and had custom throttle cables made by a local garage. I also extended the wiring from the switch gear.
This is my build thread, which may help you.
Jayne you're a Pussy Magnet
Old 21-07-14, 12:44 PM   #3
Dalerst
Default Re: Pointy S bar conversion?
Thanks, No sure I want to have them on such a long clamp, I was hoping to re route my throttle cables and just buy a new clutch cable. already have the brake lines so that sorted.
Old 21-07-14, 01:00 PM   #4
give Matt a call (CNC) i'm sure he will sort you out with new throttle cables.
although people have used the shorter (OEM) cables it's best to get the proper ones and be done with it.
something everyone else fails to mention is the extension of the switchgear cabling and most people bodge this as well. do it right do it once.
Old 31-07-14, 09:31 AM   #5
Dalerst
Got my bar and risers on order which will hopefully be hear today, will start the conversion at the weekend and get some photos of the finish task up.
Old 31-07-14, 10:21 AM   #6
Trev B
Trev B's Avatar
I had the full kit off Matt for my L2,this included new throttle cables,but ran the old clutch cable at the back of the top yolk instead of the front and found no reason to re route it anywhere else,bought some s/h switchgear and cut and soldered the wires accordingly and gave them an inch or two of slack,tyrapped looms to bars!job done!!!
Trev B is offline   Reply With Quote
Old 31-07-14, 11:37 AM   #7
Dalerst
did you need to replace the throttle cable? ive been told that you can re route them and they are fine?
Old 31-07-14, 03:31 PM   #8
Trev B
Trev B's Avatar
I suppose it depends on the height of the risers and the bars you use,mine are Renthal lows,but my kit came with new throttle cables which are well long,if the bars are not too high re routing them through the hole in the other side of the frame may well be enough,it's a bit tricky trying to get the nipples back into the bottom of the throttle cable carrier but just need a bit of patience !!!
Old 31-07-14, 03:34 PM   #9
Trev B
Trev B's Avatar
Dalerst......sorry bud,have a look on TopYolks site and look at customers pictures,they have different bikes on but it might give you some idea!!!
Old 01-08-14, 08:09 AM   #10
Dalerst
Stage 1 complete Risers fitted
Pointy Fairings please (N to S conversion) Wayno Stuff Wanted 4 29-12-14 06:10 PM
LSL bar conversion removal, Pointy. Mikey360 SV Talk, Tuning & Tweaking 6 09-06-14 08:15 PM
SV Pointy Comfort Bar Conversion aliwakeskate For Sale - SV's and SV related items 1 02-09-12 09:10 PM
Mph - Kph conversion on a pointy? Fee Bikes - Talk & Issues 7 30-06-08 06:48 PM
K3 Pointy Bar conversion chris600v For Sale - SV's and SV related items 4 02-03-08 10:10 AM
