Old 21-07-14, 05:32 PM   #1
Ravenhearts
Default Coloured engine bolts?
Hello guy I wonder if you can put my mind at rest I have seen some engine bolts these linked http://www.bustersclassic.co.uk/prod...asp?prod=PB003 and wondered if they are safe to use, I was just going to use stainless steel ones but I do like the look of these Thanks in advance
Old 21-07-14, 07:03 PM   #2
drewthejew94
Default Re: Coloured engine bolts
i ive had that set on mine for six months same colour and they are fine no discolouration and i wash it every week
Old 21-07-14, 07:17 PM   #3
Ravenhearts
That's great thanks for your reply
Old 21-07-14, 08:14 PM   #4
jambo
jambo's Avatar
Safe, yes. Better quality than original bolts? Unlikely. To your taste? Only you can say, but I'd certainly keep the originals as these sort of things don't suit everyone and can put some people off if you decide to sell down the line.
Jambo
Sent without a real keyboard
Old 22-07-14, 10:09 AM   #5
Jayneflakes
Jayneflakes's Avatar
I am not a fan of aluminium bolts for engines, the strength is not great in aluminium when compared with steel bolts, so I used a full stainless set from Chewy's.
http://www.chewys-stuff.co.uk/
The stainless bolts are polished and look lovely as well as still being strong.
Jayne you're a Pussy Magnet
Old 22-07-14, 11:25 AM   #6
TamSV
TamSV's Avatar
They're OK to use in non-stress situations - fairing and engine bolts for clutch case etc will be safe.
HOWEVER they're much softer than standard. If you take them off regularly you'll quickly round them off. If you don't take them out regularly you might need to drill them out.
Quite a few members on here have used the coloured alloy bolts and gone back to standard or stainless for that reason.
Personally, I'd use stainless.
Old 23-07-14, 07:10 AM   #7
muzikill
muzikill's Avatar
Default Re: Coloured engine bolts?
+1 for chewies stainless bolt set.
Sent from my GT-I9505 using Tapatalk
Old 23-07-14, 09:12 AM   #8
Heorot
Over time, aluminium will almost weld itself to steel. I learnt this to my cost when I used aluminium tyre valve caps. I went to check tyre pressures and the caps were impossible to remove. They had to be cut off with a hacksaw.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 23-07-14, 01:02 PM   #9
Jayneflakes
I am not a metallurgist, but I understand the process to be ionic exchange between dissimilar metals, that leads to a layer of aluminium oxide between the aluminium and the other metal. This layer is significantly thick and will seize the joint or thread, however a good coat of copper grease should prevent this from happening. Aluminium is highly reactive anyway and will almost instantly react with atmospheric oxygen, so will always have a thin oxide layer.
My concern with using aluminium engine bolts is the need to have them tight, but also having the ability to reuse the bolts after engine work. A high quality Allen key is also needed to ensure that the head is not damaged because the soft metal is far easier to ruin that a good stainless one.
Anodised engine bolts? drewthejew94 SV Talk, Tuning & Tweaking 6 24-05-14 06:30 PM
Removing engine bolts. andrewsmith SV Talk, Tuning & Tweaking 8 02-01-11 08:56 PM
engine bolts for point engine pookie Stuff Wanted 6 01-10-10 01:50 PM
Engine Bolts? chiangbANG! SV Talk, Tuning & Tweaking 1 02-04-07 09:35 AM
Coloured Bolts? ben650 SV Talk, Tuning & Tweaking 17 20-11-05 08:59 PM
