Old 31-07-14, 04:55 PM   #1
Flameboy
Default Easiest electrical fix and LED headlights?
Hi Guys,
I have recently bought a 2001 Suzuki Gsf600 bandit (with those daft oo <--- twin headlights) Anyway around the front end their is exposed wire connectors and cracked rubber casings/covers - picture attatched - I'm assuming they are not made to withstand torrential rain and as i use the bike as a commutter it will get wet! what would be the best way to seal all this up, wrap it all in black tape or have it all done properly in new casings? or another option??
Question 2, LED headlights - I have seen these on ebay for around £60 and i'm wondering if anyone has them on their bike and how effective they are? and if they are any good how difficult are they likely to be to install?
The headlights V
http://www.ebay.co.uk/itm/Universal-...item20e4368bde
Kind regards, Flame
Old 31-07-14, 07:30 PM   #2
tigersaw
tigersaw's Avatar
Default Re: Easiest electrical fix and LED headlights?
two ideas - 1: pack them with ACF50 grease. Have dowen that on my trail bike electrics and that has been *underwater* several times with no electrical issues.
2: self amalgamating tape rather than insulation tape. I use it on outdoor electrical installations and it works well.
The headlight looks crap. 3x3 watt LED isn't going to cut any mustard on a vehicle. Thats just 3 bright torches really. It does distance itself from saying its legal if you notice by saying its for a project bike.
Old 01-08-14, 09:18 PM   #3
DanSp
DanSp's Avatar
Can you email them and ask for some more specs? Like the Lumen output which will give you an idea of what its actual performance will be?
DanSp is offline   Reply With Quote
Old 04-08-14, 07:50 AM   #4
LED headlights no no no no.
Cheap chinese optics, poor thermal properties, crap current regulation, worse beam...
Old 04-08-14, 05:08 PM   #5
Flameboy
Ok so for something brighter than your standard bulb, what would you suggest? is it possible to put a halogen bulb in (are they the bright white light ones?)???
And the cables have turned out to be for my heated grips.. still going to cover them with the tape you suggested
Old 04-08-14, 09:21 PM   #6
I would get some good quality halogen bulbs (osram nightbreakers, etc) and make sure the wiring is decent to a normal headlight.
HIDs are alright but always scattery and don't seem to throw as much as you'd like.
Normal halogens just work.
And get rid of the daft streetfighter wannabe lamps, stock headlights must be cheap enough surely
Old 05-08-14, 12:22 PM   #7
SUPERSTARDJ01
it would have to be led projector headlights or HID
Old 06-08-14, 07:00 PM   #8
Flameboy
I've managed to get two 120% brighter than normal bulbs from halfords and they're actually pretty good, not cheap though £34 for two... Still going to look into a standard headlight when i manage to find one.
The self amalgamating tape has done the trick as well, looks pretty tidy as well... good recommendation
Thanks!
Old 06-08-14, 09:18 PM   #9
Tomor
Tomor's Avatar
:O Osram nightbreakers are £12 a pair on amazon
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Which is easiest panel to remove? ruddlad SV Talk, Tuning & Tweaking 9 19-07-12 04:22 PM
Easiest way to remove small amount of Oil? Dunn-y SV Talk, Tuning & Tweaking 13 04-12-11 03:07 PM
Want to get your downpipes clean - EASIEST WAY rob13 Bikes - Talk & Issues 64 30-08-11 07:29 PM
Easiest way to get super glue off paint work? cringer Idle Banter 11 15-06-10 09:32 PM
easiest forks to fit gregsv650 SV Talk, Tuning & Tweaking 3 11-05-07 11:46 PM
