Old 05-08-14, 02:34 PM   #1
aesmith
Default SV650S K6 - Sump plug washer size?
Hi,
To save me removing the drain plug, can anyone tell me what size washer is needed for the sump drain plug? Last oil change I the dealer included a washer, but it was the wrong size, so what with one thing and another I've now done three oil changes and had to re-use the washer each time. I want to get a couple for stock before the next change is due.
Thanks, Tony S
Old 05-08-14, 03:13 PM   #2
Default Re: SV650S K6 - Sump plug washer size?
M13 x 18mm
Old 05-08-14, 03:15 PM   #3
aesmith
Perfect, thanks.
Old 06-08-14, 01:00 PM   #4
muzikill
muzikill's Avatar
Ebay always has a few dealers selling the oem crush washer. No need to measure. Just do a search with your make and model and they usually come up.
Old 06-08-14, 01:22 PM   #5
aesmith
Cheers. I've just ordered a pack of 5 copper washers. I prefer them to the existing aluminium, as the copper ones can be reused after annealing.
Correct sump plug washer? cornishsv SV Talk, Tuning & Tweaking 1 13-03-14 11:07 AM
sump plug washer dimensions. SAMMY650 SV Talk, Tuning & Tweaking 9 03-04-10 09:02 PM
Sump plug washer - where from? pencil shavings SV Talk, Tuning & Tweaking 26 17-03-09 08:52 PM
Sump plug washer yorkie_chris SV Talk, Tuning & Tweaking 3 29-09-07 10:44 AM
