Old 30-08-14, 08:50 PM   #1
Gaz.sv650
Gaz.sv650's Avatar
Default LED headlight?
Would a led bulb be able to do hi/low beam? Like the twin filament standard bulb?
I am fully prepared to be called a noob if this is very obvious, so please go to town
http://www.ebay.co.uk/itm/1-X-Car-H4...item5b00eb3449
Gaz.sv650 is offline   Reply With Quote
Old 30-08-14, 09:03 PM   #2
Default Re: would this work?
No
And please forget you ever heard that LED bulbs exist
Old 30-08-14, 09:10 PM   #3
Gaz.sv650
Gaz.sv650's Avatar
Thanks didn't think so.
How come? I have a single led bulb light for my push bike and its fantastic
Old 30-08-14, 09:13 PM   #4
Ok the proper ones do work. But that one you linked may as well be made of wax and a piece of string
Old 30-08-14, 09:16 PM   #5
Gaz.sv650
Gaz.sv650's Avatar
Haha yeah that was just the first one that came up on eBay for a example
So the better quality ones can do hi/low?
Old 30-08-14, 09:19 PM   #6
No. Unless you have individual housings for high and low.
Old 30-08-14, 09:24 PM   #7
Gaz.sv650
Gaz.sv650's Avatar
I think I will accept your first advice and forget all knowledge then thanks buddy
Old 31-08-14, 11:47 AM   #8
I suspect that this technology will filter down to replacement bulbs at somepoint.
But its not in the bulb manufacturers interest is it.
For push bikes they're perfect, long battery life & great illumination
Old 31-08-14, 02:21 PM   #9
Red ones
Red ones's Avatar
Default would this work?
The problem is not so much the lamp as fitting. The fittings for H4 lamps are shaped so that the different positions of the 2 filaments result in a different position of the focused beam from the light. The LED replacement doesn't have the two filament positions. It's not so much an H4 replacement lamp as an LED lamp that's the same shape as an H4.
To get LED main and dipped beams you would need separate lamps and fittings. This might be why it was an 'H4 fog light' not a headlight.
The power is possible from LED the issue is more one of cost and heat dissipation from the fitting.
Old 31-08-14, 02:49 PM   #10
NTECUK
NTECUK's Avatar
There are Cree bulb replacements. But you need to remember that the reflector for an incandescent light source is not going to be the same as a Cree lens.
Indicators work, hazards don't work properly. DanSp SV Talk, Tuning & Tweaking 2 03-02-13 10:52 AM
How many of us out of work tonyt Idle Banter 32 19-12-08 08:05 AM
Someone come work with Paws Idle Banter 29 20-03-07 10:59 PM
When I got off work... neuone Photos 14 31-05-06 08:05 PM
Will this work on a K4? Diveboy SV Talk, Tuning & Tweaking 7 21-05-06 12:06 AM
