13-09-14, 10:01 PM | #1 |
Curvy seized carb adjuster screw removal?
any hints in trying to get the adjust Screw out of the carbs without shredding up the brass screw? also if they come out how do you keep them from seizing?
Thanks!!! |
14-09-14, 06:23 PM | #2 |
To which screw are you referring? I suspect it is the pilot mixture adjuster - can you confirm this?
16-09-14, 06:08 PM | #3 |
Re: Curvy seized carb adjuster screw removal?
Yes the brass one that sits upside down when the carbs on the bike. I was debating putting it In a ultra sonic bath to get it out
16-09-14, 07:17 PM | #4 |
Have a look here:
http://forums.sv650.org/showthread.php?t=212163
Curvy airbox/carb clamp screw size? | daveyrach | SV Talk, Tuning & Tweaking | 2 | 31-07-13 02:06 PM |
K2 Seized idle adjuster. | kd80 | Bikes - Talk & Issues | 5 | 15-07-10 10:51 PM |
Chain Adjuster Bolts Seized - Curvy | JamesMio | SV Talk, Tuning & Tweaking | 4 | 25-02-09 04:44 PM |
Tickover Adjuster Seized | TheShadow | SV Talk, Tuning & Tweaking | 4 | 22-09-08 09:56 AM |
Chain adjuster seized. | Scoobs | Bikes - Talk & Issues | 24 | 05-03-06 06:55 PM |
