I had to revert back to Stock rearsets and fitted them in myself but I am missing a bit!
The part that connects the actual lever to the threaded part that goes into the 'button thingy'. ''The brake hight adjustment piece'' So basically my pedal is not connected to anything and when pressed down it just knocks in to the button and pushes it up. I should say the image below IS NOT MY BIKE but found on Google and its showing the piece I need. ![]() I should say the image above IS NOT MY BIKE but found on Google and its showing the piece I need. Does anyone have a spare one of these or know where I can buy one? Last edited by ManMango; 14-09-14 at 04:16 PM. Reason: image |
Fairly sure i may still have this. Will check for you
sent from a galaxy far far away (from a bike) |
Still after this clip between master cylinder and brake lever. My bike is off the road at the moment mainly because of this! So please anyone who has third party rear sets can you check you box of bits at the back of the garage?
I found out what its called. A rear brake Yoke!!! I need this + clips if anyone has.
Rear Brake Reservoir Screw | M65 | Stuff Wanted | 0 | 02-03-13 08:20 PM |
Curvy brake lever & rear brake pedal | Old Git | Stuff Wanted | 1 | 09-01-10 11:00 AM |
anyone got a Rear Brake Pedal | tonyk | Thames Valley | 7 | 06-09-09 06:48 AM |
Rear Brake Pedal | 01 sv650s | Stuff Wanted | 1 | 29-03-07 10:11 PM |
Rear brake hose clip thingy | oldjack | SV Talk, Tuning & Tweaking | 2 | 09-03-07 11:35 PM |
