Old 30-10-14, 01:00 PM   #1
garynortheast
garynortheast's Avatar
Default Oil leak from output shaft seal or pushrod seal
Got a bit of a leak on my 650sy either from the output shaft oil seal or from the clutch push rod oil seal. Haven't had a chance to determine which yet.
Are both/either of these replaceable without a major dismantling? I seem to recall the output shaft seal can be levered out and replaced once the front sprocket is off the bike. Am I right on this?
What about the push rod seal? On which side of the engine is this? I have a suspicion that it's behind the clutch, so clutch off?
Cheers....
Old 30-10-14, 01:22 PM   #2
jambo
jambo's Avatar
Default Re: Oil leak from output shaft seal or pushrod seal
Hi Gary,
Worth checking the front sprocket is tight, you sometimes get a leak there if the sprocket's come a bit loose.
Once you've done that clean the whole area up with paraffin or something and go for a ride, use a pit of talc powder if needed to see where the oil is coming from.
Jambo
Old 30-10-14, 02:55 PM   #3
Biker Biggles
Biker Biggles's Avatar
Also worth cheching the crankcase breather pipes(2)are still properly in place.One of them can blow oil out in that area.
Old 30-10-14, 06:27 PM   #4
Corny Gizmo
+1
Gear selector shaft seal replacement? andrewsmith SV Talk, Tuning & Tweaking 0 27-05-14 09:10 PM
Fork seal leak help? craig dow SV Talk, Tuning & Tweaking 11 16-03-13 01:36 PM
Output Shaft Oil Seal (where to buy) Scott S Bikes - Talk & Issues 5 15-04-11 08:21 PM
Oil leak output shaft help mattc SV Talk, Tuning & Tweaking 3 05-05-08 05:48 PM
Oh dear- leak from front sprocket shaft seal? northwind SV Talk, Tuning & Tweaking 12 12-05-05 02:47 PM
