Old 16-11-14, 12:09 PM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Default Boiler help
Got home last night to find that my boiler hadn't fired up, hit reset and it started working. This morning It's done it again but the reset does nothing. I've switched the power on and off a few times and still no worky.
The code it gives me is telling me that there is a flame detection error/short circuit. The flow chart in the manual states..... unplug the the flame detection electrode from the pcb and check continuity:
YES continuity - replace the electrode
NO continuity - replace the pcb.
I have continuity on the electrode so surely that means the electrode is working and the fault is with the PCB?
but then that means the manual is wrong
I'm so confused.
05 DRZ400E
RIP hovis
Old 16-11-14, 12:21 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: Boiler help
Just powered up the pcb and checked the continuity on the board, when i connect the multimeter to the terminals on the board the controls click and causes the error message to change. I plug the electrode back in, the control clicks back to idle, I flick the heating back on and it's all working.
So maybe it is the electrode
05 DRZ400E
RIP hovis
Old 16-11-14, 12:49 PM   #3
Wideboy
Evel Knievel
Wideboy's Avatar
It stops with a flame error, I hit reset and I get a flame dection error again, I pull out the flame detection plug and plug it back in and everything works as normal for a few mins then it shut down back to flame error.... then the process starts again.
fairly sure it's the sensor then.
05 DRZ400E
RIP hovis
Old 16-11-14, 01:57 PM   #4
Spank86
You seem to have this fairly well in hand.
Clearly no need for me to google a bunch of crap to add here just yet.
Old 16-11-14, 04:21 PM   #5
Rumble bee
Potterton combi by any chance?
Old 16-11-14, 05:45 PM   #6
Wideboy
Evel Knievel
Wideboy's Avatar
no a $hitty ideal icos
05 DRZ400E
RIP hovis
Old 16-11-14, 05:46 PM   #7
Wideboy
Evel Knievel
Wideboy's Avatar
but the org isn't the org without some kind of vain googlefu attempt at knowledge.
05 DRZ400E
RIP hovis
Old 16-11-14, 05:52 PM   #8
Heorot
We had a similar problem with our Ideal boiler. It required a replacement PCB costing over £200.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 16-11-14, 05:54 PM   #9
You're a joiner. Phone a plumber
Old 16-11-14, 06:19 PM   #10
Spank86
In that case you clearly need to replace your fuse box.
the whole thing, replace it with old style fuses where you wind the wire on yourself but use paperclips so that it can't blow and spoil everything.
old crap boiler - help please! johnnyrod Idle Banter 6 24-12-10 07:27 PM
Boiler issues! MisterTommyH Idle Banter 9 10-12-10 01:31 PM
Is this boiler any good? BoltonSte Idle Banter 20 12-01-10 01:39 PM
Another Boiler Problem! DarrenSV650S Idle Banter 11 05-01-10 06:55 PM
gas boiler has gone steveg Idle Banter 14 06-10-07 10:46 AM
