Old 27-11-14, 04:49 PM   #1
steve1971
Default Pointy won't start.
Hi all i'm new to the forum and this is my first post and am in need of dire help.
I commute on my SV650S 2004 model and had it a year and had no issues what so ever until weds, came back sunday from a short ride out and the bikes been out in ALL weathers storms ect you name is.
Weds afternoon had a hot date with a chick and it wouldn't start....even when jumped from a car battery.
Checked the following
ALL electrical connections
Plugs ( new one coming tomorrow just in case) had spark
Fuel pump comes on when FOB pressed
Fresh fuel in tank
clutch and side stand switches work
and freshly charged battery which was replaced in April/May this year.
Only thing i noticed is that both headlight bulbs had blown ???!!!???
Thoughts from the collective much appreciated.
Steve
Old 27-11-14, 04:55 PM   #2
Tomor
Tomor's Avatar
Default Re: SV650S Won't fire up?!?!?!
Kill switch. Have you. Checked the kill switch?
Sent from my magical portable device
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 27-11-14, 04:58 PM   #3
steve1971
Should turn over if the kill switch is active ?????? Surely ? Battery on charge at present
Old 27-11-14, 06:07 PM   #4
steve1971
also even in neutral i have to pull in the clutch to start is this normal ?
Old 27-11-14, 06:13 PM   #5
Tomor
Tomor's Avatar
It wouldn't turn over if the kill switch is in the 'off' position. Yes you also need to pull in the clutch to start it .
Old 27-11-14, 06:22 PM   #6
steve1971
Hmmmmmmmmmmmm will put cleaner in the injector tomorrow fit the new plugs and wd40 everything ?!?!
Spark is good can't understand is there and diagnostic reset or something or a safety bullsh*t because the head lights blew ?
Old 27-11-14, 06:32 PM   #7
jambo
jambo's Avatar
Let's be really clear on what is and is not happening.
From what you've written above:
1) Bike was working fine, left for a short period, nothing has happened to it between it running and not, however trivial.
2) The bike turns on with the ignition and display lights up, fuel pump can be heard to prime.
3) The bike turns over strongly on the button
4) There is a spark from both plugs when removed and grounded against a good earth.
5) The bike does not splutter, cough or smell of fuel.
6) The headlights have both blown.
7) There are no errors shown on the dash when the bike is turning over or before the starter button is pressed.
Does all of the above sound correct, or is anything not as above?
More importantly, were you able to find another way to get to that date?
Jambo
Old 27-11-14, 06:40 PM   #8
steve1971
The bike did smell of fuel from the exhaust pipe, if the battery is faulty and not enough amps maybe the spark isn't strong enough. But is should of started via a jump from a car!
Other thought is what about automatic choke, throttle sensor ect
Old 27-11-14, 06:41 PM   #9
steve1971
Date is for ssturday now so no pressure i live in the sticks
Old 27-11-14, 07:30 PM   #10
jambo
jambo's Avatar
Please confirm exactly what does and doesn't happen.
Generally speaking if the battery is strong enough to turn the motor over, it's got enough power to make a spark, but unless we get methodical about what is and isn't happening here we're all just guessing and listing components.
Jambo
Fake fire place surround and fire. FREE Ch00 Idle Banter 6 09-09-14 03:26 PM
OMO: Gas Fire -Ralph- Idle Banter 11 02-12-12 06:20 PM
Fire in the sky. rictus01 Photos 10 12-10-09 11:09 AM
Fire & Ice Kinvig Idle Banter 4 09-11-07 03:37 PM
