If you've got a bog standard curvy engine making 73bhp on the dyno with a one-off exhaust system and you're looking for a reliable 85bhp, or more, with the same exhaust system would you expect the following to deliver?
http://www.spearsenterprises.com/99-02-sv650.html
These guys have been building SV650 race engines since the beginning. I think maybe the standard carbs would be your limiting factor... |
Give these guys a call http://www.jhsracing.co.uk/suzuki_SV.htm
I know what the engine builders/tuners say, I'm looking for real feedback from people who've got engines with those kind of mods.
I remember one being told by a very well respected engine tuner that you always have to choose between power, flexibility and reliability. You can have pretty much any two, but not all three.
There are a few recognised experts out there who have developed SV engines through the pressure of motorsports, and if there was an easy gain to be made they would have found it by now. Having said that 85bhp isn't a huge ask and I seem to remember when I looked into it a few years back most of the mods you list were mentioned, although I have a fuel injected Pointy. Have you priced up what you are suggesting yet? I can assure you it's not just a case of picking up a few second hand pieces and throwing them together, so unless you really need that extra few BHP because you are racing in an appropriate class then most people just sell their SV and get a SS600. |
#6 | |
Comments added:
Re. the carbs, any improvements in gas flow will make it leaner, and dyno set up sorts this out. The stock carbs aren't small so I would think they are good enough. After cams you are really into head work, and this is where the bhp returned for your cash is tailing off quite badly. With a 700cc kit, midrange is impressive but top end is curtailed (to a similar figure to a 650, from what I've seen, though with that much extra midrange who cares), so you need to up the gas flow, by polishing and porting, and doing some work with the squish. This is all quite intense stuff and really, even for me, isn't worth it. I got hold of a set of polished and ported heads from a Supertwin but I haven' had the dyno work done to sort out the fuelling, but I wouldn't have forked out full whack for it. For reliability, if you go the 700cc route or really try to get much over 80bhp then you should be looking at new rods and cylinder studs. Because the crankcases split vertically then it's a big job, so may as well do the crank work too while you're in there. I'm no tuning expert but I've done a lot of reading around, and a bit of tinkering with mine too. If you want another tuner I'd recommend then talk to Steve Jordan. Whatever you do, you're going to need deep pockets, so unless you're really after making something special, you already know I'm going to say do the cam swap (which oddly needs no further dyno work) and spend the rest on ways to ride it. |
Or fit a turbo. I always thought this would be a ludicrous thing to do with an sv and absolutely certainly lead to a motor being blown to bits but a couple of people have managed it. I'm not sure either have done big miles but it didn't seem to grenade.
Jambo Sent without a real keyboard
That was an article many years ago in MCN on an SV650 bored out to 800cc vs a ducati (possibly monster). It detailed the work done on the SV but I can't find it now.
#9 |
To get 85 brake reliable your really having to look at:
new custom crank (900 notes upwards), rods and pistons (about 700), flat side carbs (last set I spotted were around 600 before shipping from the states) Then what has been already mentioned
#10 | |
I ask, because every engine builder I've spoken to says the standard crank - if lightened and balanced with a lightened flywheel - is more than capable of handling that power output reliably and the standard carbs, if rejetted, do not hold the engine back. |
Most reliable manufacturer? | matt_rehm_hext | Bikes - Talk & Issues | 62 | 22-11-11 07:17 AM |
Sat nav or car most reliable | Messie | Idle Banter | 10 | 31-03-09 12:34 AM |
need a reliable tuner | mickeymac | SV Talk, Tuning & Tweaking | 9 | 07-11-08 05:22 PM |
Something cheap, reliable and fun? | krhall | Bikes - Talk & Issues | 60 | 27-08-08 02:14 PM |
Anyone looking for a reliable bike? | gavinsky23 | SV Ecosse | 3 | 07-04-08 11:58 AM |
